跳转到主内容
Shark Matrix RV2310 Brushroll Replacement
Joshua Correia
Joshua Correia2 其他贡献者
最后更新于 June 13, 2024
2分钟
简单
This guide will show you how to replace the brushroll of the Shark Matrix RV2310. This replacement may be used to solve issues with the vacuum collecting debris. It is a fairly easy process, though it is important to ensure that the battery is removed first so that the vacuum is off during this process.
你所需要的
工具
  1. Shark Matrix RV2310 Brushroll Replacement, Battery: 步骤 1 中的图像 1,3 Shark Matrix RV2310 Brushroll Replacement, Battery: 步骤 1 中的图像 2,3 Shark Matrix RV2310 Brushroll Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
  2. Shark Matrix RV2310 Brushroll Replacement: 步骤 2 中的图像 1,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 2 中的图像 2,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 2 中的图像 3,3
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
  3. Shark Matrix RV2310 Brushroll Replacement, Brushroll: 步骤 3 中的图像 1,2 Shark Matrix RV2310 Brushroll Replacement, Brushroll: 步骤 3 中的图像 2,2
    • Remove the three 8 mm Phillips screws from the plastic plate holding the brushroll in.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
  4. Shark Matrix RV2310 Brushroll Replacement: 步骤 4 中的图像 1,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 4 中的图像 2,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 4 中的图像 3,3
    • Press in the two tabs on the side of the plate and pull upward to remove it.
  5. Shark Matrix RV2310 Brushroll Replacement: 步骤 5 中的图像 1,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 5 中的图像 2,3 Shark Matrix RV2310 Brushroll Replacement: 步骤 5 中的图像 3,3
    • Pull up on the darker orange side of the brushroll to remove it.
结论
Joshua Correia
于03/22/24注册
607 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-4, Botvin Spring 2024 UMass Dartmouth, Team 6-4, Botvin Spring 2024 的会员
UMASSD-BOTVIN-S24S6G4
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 125
