跳转到主内容
Shark IONFlex 2X Battery Replacement
Kendal Cler
Kendal Cler2 其他贡献者
最后更新于 September 19, 2022
1分钟
非常容易
需要更好的图片
The lithium-ion power pack in the Shark IONFlex 2X is easily replaced by the user with no tools required. The Shark IONFlex 2X comes with two power packs that can be used in the unit and recharged in a separate charging unit. One battery can be used while the other is charging for convenience.
  1. Shark IONFlex 2X Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Squeeze the lever located at the bottom of the lithium power pack labeled “Battery Release”.
  2. Shark IONFlex 2X Battery Replacement: 步骤 2 中的图像 1,1
    • While squeezing the lever at the bottom of the power pack, pull out the battery pack to remove the battery.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 1,938
