跳转到主内容
Shark Cordless Pet Perfect Front Belt Replacement
Ben Dzugen
Ben Dzugen4 其他贡献者
最后更新于 September 13, 2022
10分钟
简单
If you are having a problem with your device's Front Belt, Here is a Step by step guide to replace a faulty or broken Front Belt.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: 步骤 1 中的图像 1,2 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: 步骤 1 中的图像 2,2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: 步骤 2 中的图像 1,3 Shark Cordless Pet Perfect Front Belt Replacement: 步骤 2 中的图像 2,3 Shark Cordless Pet Perfect Front Belt Replacement: 步骤 2 中的图像 3,3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: 步骤 3 中的图像 1,3 Shark Cordless Pet Perfect Front Belt Replacement: 步骤 3 中的图像 2,3 Shark Cordless Pet Perfect Front Belt Replacement: 步骤 3 中的图像 3,3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: 步骤 4 中的图像 1,2 Shark Cordless Pet Perfect Front Belt Replacement: 步骤 4 中的图像 2,2
    • Remove the belt from the motor mount, and then replace with a new belt.
结论
Ben Dzugen
于02/02/17注册
383 声望
创作了3篇指南
团队
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G2
4 名成员
创作了11篇指南
2指南评论
Nice and simple but where can we purchase the belts?
jmrlachance - 回复
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 46
总计 2,960
