跳转到主内容
加入维修社区 - 创建账户
Samsung WB350F Menu/Control Buttons Replacement
你所需要的
    1. Samsung WB350F Menu/Control Buttons Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung WB350F Menu/Control Buttons Replacement, Rear Case: 步骤 1 中的图像 3,3
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      询问修复机器人
      添加评论
    2. Samsung WB350F Menu/Control Buttons Replacement: 步骤 2 中的图像 1,3 Samsung WB350F Menu/Control Buttons Replacement: 步骤 2 中的图像 2,3 Samsung WB350F Menu/Control Buttons Replacement: 步骤 2 中的图像 3,3
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      询问修复机器人
      添加评论
    3. Samsung WB350F Menu/Control Buttons Replacement: 步骤 3 中的图像 1,3 Samsung WB350F Menu/Control Buttons Replacement: 步骤 3 中的图像 2,3 Samsung WB350F Menu/Control Buttons Replacement: 步骤 3 中的图像 3,3
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      询问修复机器人
      添加评论
    4. Samsung WB350F Menu/Control Buttons Replacement: 步骤 4 中的图像 1,1
      • Remove the plastic casing, exposing the inner workings of the camera.
      询问修复机器人
      添加评论
    1. Samsung WB350F Menu/Control Buttons Replacement, Screen: 步骤 5 中的图像 1,2 Samsung WB350F Menu/Control Buttons Replacement, Screen: 步骤 5 中的图像 2,2
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      询问修复机器人
      添加评论
    2. Samsung WB350F Menu/Control Buttons Replacement: 步骤 6 中的图像 1,1
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      询问修复机器人
      添加评论
    3. Samsung WB350F Menu/Control Buttons Replacement: 步骤 7 中的图像 1,1
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      询问修复机器人
      添加评论
    4. Samsung WB350F Menu/Control Buttons Replacement: 步骤 8 中的图像 1,2 Samsung WB350F Menu/Control Buttons Replacement: 步骤 8 中的图像 2,2
      • Remove the silver panel.
      询问修复机器人
      添加评论
    5. Samsung WB350F Menu/Control Buttons Replacement: 步骤 9 中的图像 1,2 Samsung WB350F Menu/Control Buttons Replacement: 步骤 9 中的图像 2,2
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      询问修复机器人
      添加评论
    6. Samsung WB350F Menu/Control Buttons Replacement: 步骤 10 中的图像 1,2 Samsung WB350F Menu/Control Buttons Replacement: 步骤 10 中的图像 2,2
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      询问修复机器人
      添加评论
    1. Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: 步骤 11 中的图像 1,3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: 步骤 11 中的图像 2,3 Samsung WB350F Menu/Control Buttons Replacement, Menu/Control Buttons: 步骤 11 中的图像 3,3
      • Gently pull the ribbon in order to remove the menu/control button panel.
      • The ribbon isn't secured with a connector and you are able to pull it straight out.
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G2
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 48
总计 1,734
