简介
This guide shows how to remove and replace a broken icemaker assembly in your Samsung refrigerator.
This guide will work for most French-door Samsung refrigerators where the icemaker is in the freezer compartment. If your icemaker is in the refrigerator compartment, follow this guide instead.
This guide is based on a model RF28T5001SR refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
This type of icemaker uses a twisting mechanism to loosen the ice cubes from the plastic ice tray. Oftentimes, the tray cracks from repeated operation and the mechanism won't release the ice cubes anymore.
你所需要的
Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
Repeat the rail unlock procedure on the other drawer rail.
Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
Remove the freezer drawer.
Push the geared torsion bar until it rests at the very end of the rails.
Align the drawer rails to the refrigerator wall guides.
Close the freezer drawer until the rails lock back in place.
Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
Grasp the front edge of the icemaker assembly and tilt it downwards.
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
