简介
This guide shows how to remove and replace the evaporator fan (aka circulation fan) in your Samsung RF28T5001SR refrigerator.
The evaporator fan circulates cold air from the evaporator coils into the freezer compartment. If your freezer isn't cooling sufficiently or evenly (the back of the compartment gets much colder), you may have a faulty evaporator fan.
你所需要的
Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
Remove the freezer drawer.
Push the geared torsion bar until it rests at the very end of the rails.
Align the drawer rails to the refrigerator wall guides.
Close the freezer drawer until the rails lock back in place.
Use a Phillips screwdriver to remove the two 18.5 mm‑long screws securing the evaporator cover to the refrigerator.
Squeeze the bottom edge of the fan connector to unlock it from the freezer wall.
Pull and disconnect the fan connector.
Use a Phillips screwdriver to remove the five 14.5 mm‑long screws securing the back panel to the evaporator cover.
Use a Phillips screwdriver to remove the three 14.2 mm‑long screws securing the evaporator fan.
另外一个人完成了本指南。
