跳转到主内容
加入维修社区 - 创建账户
Samsung Glyde LCD Screen Replacement
你所需要的
  1. Samsung Glyde LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your thumb, press down and slide the back cover away from the camera.
    询问修复机器人
    添加评论
  2. Samsung Glyde LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    询问修复机器人
    添加评论
  3. Samsung Glyde LCD Screen Replacement, Keyboard: 步骤 3 中的图像 1,2 Samsung Glyde LCD Screen Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
    询问修复机器人
    添加评论
  4. Samsung Glyde LCD Screen Replacement: 步骤 4 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
    询问修复机器人
    添加评论
  5. Samsung Glyde LCD Screen Replacement: 步骤 5 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 5 中的图像 2,2
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
    询问修复机器人
    添加评论
  6. Samsung Glyde LCD Screen Replacement: 步骤 6 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
    询问修复机器人
    添加评论
  7. Samsung Glyde LCD Screen Replacement: 步骤 7 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 7 中的图像 2,2
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
    询问修复机器人
    添加评论
  8. Samsung Glyde LCD Screen Replacement: 步骤 8 中的图像 1,3 Samsung Glyde LCD Screen Replacement: 步骤 8 中的图像 2,3 Samsung Glyde LCD Screen Replacement: 步骤 8 中的图像 3,3
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
    询问修复机器人
    添加评论
  9. Samsung Glyde LCD Screen Replacement: 步骤 9 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
    询问修复机器人
    添加评论
  10. Samsung Glyde LCD Screen Replacement: 步骤 10 中的图像 1,3 Samsung Glyde LCD Screen Replacement: 步骤 10 中的图像 2,3 Samsung Glyde LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
    询问修复机器人
    添加评论
  11. Samsung Glyde LCD Screen Replacement: 步骤 11 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 11 中的图像 2,2
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
    询问修复机器人
    添加评论
  12. Samsung Glyde LCD Screen Replacement, LCD Screen: 步骤 12 中的图像 1,2 Samsung Glyde LCD Screen Replacement, LCD Screen: 步骤 12 中的图像 2,2
    • Using a #00 screwdriver, remove the 8 2mm screws connecting the display case to the sliding mechanism.
    询问修复机器人
    添加评论
  13. Samsung Glyde LCD Screen Replacement: 步骤 13 中的图像 1,2 Samsung Glyde LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Now remove the 5 4mm screws located under the sliding mechanism connecting the back-plate to the display.
    • You will need to maneuver the sliding mechanism around to reach all of the screws.
    询问修复机器人
    添加评论
  14. Samsung Glyde LCD Screen Replacement: 步骤 14 中的图像 1,3 Samsung Glyde LCD Screen Replacement: 步骤 14 中的图像 2,3 Samsung Glyde LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Now it's time to desolder some components. You can gain some instruction from here.
    • Using your soldering wick and a soldering iron, desolder the contacts of the flex cable.
    询问修复机器人
    添加评论
  15. Samsung Glyde LCD Screen Replacement: 步骤 15 中的图像 1,1
    • After desoldering, verify that the gates on the two flex cables are in the "up" position and remove them.
    询问修复机器人
    添加评论
  16. Samsung Glyde LCD Screen Replacement: 步骤 16 中的图像 1,3 Samsung Glyde LCD Screen Replacement: 步骤 16 中的图像 2,3 Samsung Glyde LCD Screen Replacement: 步骤 16 中的图像 3,3
    • Using gentle fingers, pry the LCD screen out of its housing.
    • The flex cables connecting everything to the LCD screen are very sensitive to touch, and don't react well to pulling/tearing motions.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Cameron Law
于10/12/11注册
142 声望
创作了5篇指南
团队
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G12
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 2,639
