Samsung Gear 2 Battery Replacement
简介
转到步骤 1This guide will walk you through the process of replacing a dead or dying battery in a Samsung Gear 2.
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Use the pointed side of the spudger to remove the small, orange battery cable.
I just broke the Orange battery cable. DAM!!!!! WHAT DO I SUGGEST
How did you do that?
Remove the battery by pulling the white tab on the battery marked "PULL."
26等其他人完成本指南。
15条评论
Where can one find said replacement battery. I had it on in less than a meter of water for less than 30 minutes and water was able to get in. Even though I did not subject it to its supposed limitations I am fairly certain that best buy or samsung will check the water indicator paper and tell me that it was my fault. I have taken it apart and gotten it all dried out. It will come on and function just fine and then when i unplug it it will turn off after a minute or so. At any rate, I would like to replace my battery but need to find one first.
Where can I find a battery I have looked everywhere including Ebay and Amazon?
I am looking for a battery also mine is very bad after 1 year. Were you able to find one?
Try this link...
berk1 -
I left my Gear 2 in a drawer for about a year and I couldn't get it to charge. I tried plugging into a usb in a laptop/desktop and a bunch of different cords. Samsung said it would cost $226 to fix, I bought this battery off of ebay and it has been working for the past 3 weeks. I will try and add a comment later after i have had it longer, but so far so good.
I need a battery for my Samsung gear watch but am kisumu n it is not there in samsung branch in kisumu how can i b helped
where can I get a replacement battery for a gear 2 neo fd81. Have tried all above links with no joy
I had to hit reset Gear to have reconnect to my phone, it's been stuck in Gear rebooting for a week. Will removing the battery help
My Gear 2 does not light up(or is very dim as if it`s going to fade out). In any case, it does not function. Should the battery be replaced? Or is it something wrong with the display? Please advise.
