跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S5 Home Button Replacement
你所需要的
    1. Samsung Galaxy S5 Home Button Replacement, Home Button: 步骤 1 中的图像 1,1
      • This guide is a conditional add-on to the Galaxy S5 Display Assembly guide. If you need to replace your home button but have not yet opened your device, start here.
      • The clear rubber backing of the home button assembly is lightly adhered to the back of the display. The adhesive should be easy to cut through with an opening tool. If you have trouble removing the assembly in the following steps, try heating the area using an iOpener or a hair dryer to loosen the adhesive.
      添加评论
    2. Samsung Galaxy S5 Home Button Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S5 Home Button Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S5 Home Button Replacement: 步骤 2 中的图像 3,3
      • Insert either end of an opening tool into the gap between the white rubber backing of the home button assembly and the screen.
      • Work your way around the bottom edge of the button, gently cutting through the adhesive holding it in place.
      询问修复机器人
      添加评论
    3. Samsung Galaxy S5 Home Button Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S5 Home Button Replacement: 步骤 3 中的图像 2,2
      • Once most of the adhesive around the bottom of the button has been broken, use your opening tool to pry it up.
      询问修复机器人
      添加评论
    4. Samsung Galaxy S5 Home Button Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy S5 Home Button Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy S5 Home Button Replacement: 步骤 4 中的图像 3,3
      • Grab the lifted portion of the home button assembly and gently pull it away from the display, tearing the rest of the adhesive.
      • As you pull the assembly away, the rubber backing may begin to separate from the home button. The home button is only connected to the rubber backing by a fragile cable, so do your best to keep them together as you pull the assembly out.
      • If you are transferring your home button to a new display, the original adhesive should be strong enough to keep it in place.
      • If the original adhesive is not strong enough to hold the button in place while you re-install the display, you can lay the button in the chassis, and then install the display over it—the display assembly will keep the button in place.
      • If you are installing a new home button, remove the plastic film covering the adhesive, then carefully align the button with the display and press it into place.
      询问修复机器人
      添加评论
结论
To finish reassembling your device, head back over to the Display Assembly guide!
取消:我没有完成这个指南。
8等其他人完成本指南。
Taylor Dixon
于06/26/18注册
72,689 声望
创作了94篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 74
总计 7,196
