跳转到主内容
Samsung Galaxy S21 Ultra Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Heat the back cover: 步骤 1 中的图像 1,1
    • Unplug and power off your phone before you begin.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Slice the adhesive: 步骤 3 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Slice the adhesive: 步骤 3 中的图像 2,2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 5 中的图像 3,3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the back cover: 步骤 7 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the back cover: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers.
    • Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Slice the adhesive: 步骤 8 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Slice the adhesive: 步骤 8 中的图像 2,2
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the charging coil: 步骤 10 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the charging coil: 步骤 10 中的图像 2,2
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the NFC antenna: 步骤 11 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the NFC antenna: 步骤 11 中的图像 2,2
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Unfasten the NFC antenna & charging coil assembly screws: 步骤 12 中的图像 1,1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the NFC antenna & charging coil assembly: 步骤 13 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the NFC antenna & charging coil assembly: 步骤 13 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the NFC antenna & charging coil assembly: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the battery cable: 步骤 14 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the battery cable: 步骤 14 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Unfasten the earpiece and laser AF module assembly screws: 步骤 15 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the earpiece speaker and laser AF module assembly.
  16. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: 步骤 16 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: 步骤 16 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: 步骤 16 中的图像 3,3
    • Use a spudger to disconnect the laser AF module and earpiece speaker flex cables by prying the connectors straight up from their socket.
  17. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the earpiece speaker and laser AF module assembly: 步骤 17 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the earpiece speaker and laser AF module assembly: 步骤 17 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the earpiece speaker and laser AF module assembly: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    • Grab the bottom right corner of the earpiece speaker and laser AF module assembly with a pair of blunt nose tweezers and carefully lift it upwards.
    • Remove the earpiece speaker and laser AF module assembly.
  18. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the front facing camera: 步骤 18 中的图像 1,2 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Disconnect the front facing camera: 步骤 18 中的图像 2,2
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
  19. Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the front facing camera: 步骤 19 中的图像 1,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the front facing camera: 步骤 19 中的图像 2,3 Samsung Galaxy S21 Ultra Front Facing Camera Replacement, Remove the front facing camera: 步骤 19 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift the front camera out of its recess and remove it.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
7等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
228,969 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,410篇指南
2条评论
What kind adhesive do i need for this repair. Is it the tape kind or what. Trying to make it have and get everything I need
Wade - 回复
thank you very much
Sacit Mensur - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 140
总计 5,570
