简介
使用本指南移除玻璃后盖,或者接触到三星Galaxy S10的内部。
你所需要的
将手机的加热右边缘放在约0.5英寸(13毫米)厚的物体上。这使手机成为打开工具的角度。
用手指支撑手机的左边缘,这样手机就不会滑动。用坚固的压力拉动吸盘。
将打开工具的边缘按入后盖和框架之间的接缝中。
沿着接缝来回几次滑动撬棒工具。
重复之前的步骤,再次试着插入撬棒。
加热 iOpener 并将其涂抹在手机的同一边缘两分钟。
在手机背面使用一个吸盘,尽可能靠近右边缘的中心(粘合剂最窄的地方)。
用强力,稳定的力拉动吸盘,在后盖和框架之间形成间隙。
将开口三角撬片的尖端插入间隙。
如果你在撬开时遇到困难,最好的办法是向边缘施加更多热量并再次尝试上一步。
你可以尝试在接缝中涂几滴高浓度(超过90%)的异丙醇,以帮助软化粘合剂。
21等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
11条评论
Hi Håkon,
Yes, opening the S10 will compromise its water resistance.
So to fix this issue and retain water proofing I should send it back to Samsung for them to repair/replace?
Håkon -
That is an option. You can also try their authorized repair centers, or independent repair centers. Note that even if they say they will restore water resistance with the repair, they will most likely not guarantee it. That is because the IP68 water resistance rating test is verified on brand new phones. As the phone ages, it loses water resistance because the seals and adhesives break down.
What about using a epoxy resin? it is only a small crack on the back, nothing major. I'll check out a service center as well.
Sorry for all the question!
Håkon -
