简介
你所需要的
让我们来看看牛7啊不note7的一些基本规格吧:
5.7寸的 Super AMOLED 曲面屏,分辨率2560 × 1440,518PPI。第五代大猩猩屏幕。
CPU是晓龙820,4G运存和高通530GPU
1200万像素搭载OIS光学防抖的相机,支持4K ,前置摄像头为500万像素,支持1080P
64GB的内存,支持扩展最高容量为256GB的MicroSD 卡
虹膜解锁和指纹解锁
Spend手写笔,type-C的USB接口和一个耳机接口
防尘和防水等级为IP68
尽管我们的拆机工程师希望能尽快着手拆机工作,我们还是花了一点时间完整测试了下S pen。
第一印象:S Pen和微软Surface Pen和苹果Apple Pencil形成了鲜明的对比:
S Pen更小巧(而且是手机自带),但是它同时具有 360hz的扫描率和4096级压感,而Apple Pencil只有240hz,Surface Pen仅有1024级的压感
这个步骤还没有翻译 帮忙翻译一下
With the motherboard deftly extracted, we take our tweezers to the hefty main camera and line him up for closer look.
It's déjà vu all over again as we pull out what appears to be the same Sony IMX260-based main camera that we uncovered in the S7 and S7 Edge.
... And the similarities go further, all the way down to:
the Winbond Q32FWXGIG serial flash memory
STMicroelectronics L2G2IS 2-Axis MEMS OIS Gyroscope
Renesas OIS Driver
这个步骤还没有翻译 帮忙翻译一下
We're down to the meat and potatoes of this teardown, and it seems like Samsung unified more than their product numbering—this chipset is nearly identical to that found in the S7 and S7 Edge.
Samsung K3RG2G20CMMGCJ 4 GB LPDDR4 SDRAM layered over a Qualcomm Snapdragon 820
Samsung KLUCG4J1CB-B0B1 64 GB Universal Flash Storage 2.0
Avago AFEM-9040 multiband multimode module
NXP PN67T NFC controller
Qorvo QM78064 high band RF fusion module, TQF6260 front-end module and QM63001A diversity receive module
Qualcomm WCD9335 audio codec and DSP Group DBMD4 audio/voice processor
Murata FAJ15 front-end module
这个步骤还没有翻译 帮忙翻译一下
More note-worthy chips hide on the backside:
Samsung 3420S7 G707A3 Wi-Fi module (most likely contains a Broadcom BCM4359 Wi-Fi SoC)
Wacom W9018 touch control IC
ZF10 110630 0625 (likely NXP Semiconductor I/O expander)
Qualcomm PM8996 and PM8004 PMICs
Qualcomm QFE3100 envelope tracker
IDT P9221S wireless power receiver (likely an iteration of IDT P9220) + Samsung S2MPB02 camera power management + Maxim Integrated MAX77838 power management IC
这个步骤还没有翻译 帮忙翻译一下
IC identification, pt. 2:
Infineon (previously Cypress Semiconductor) CY8CMBR3145 capacitive touch button controller
Samsung Image Processor (likely)
Samsung S2MM005X01 power management
Maxim Integrated MAX77854F power management
Maxim Integrated MAX98506 audio amplifier
Texas Instruments BQ25898S battery charger
ON Semiconductor FPF3688 load switch
这个步骤还没有翻译 帮忙翻译一下
IC identification, pt. 3:
RDA Microelectronics RDA6213 FM radio transceiver
Antenna switch module (likely)
NXP Semiconductor BGU8103 GPS/GLONASS/Galileo/BeiDou low noise amplifier
NXP Semiconductor BGS8H2 LTE low noise amplifier
NXP Semiconductor BGS8L2 LTE low noise amplifier
NXP Semiconductor BGS8M2 LTE low noise amplifier
Infineon BGS12SN6 SPDT RF switch
这个步骤还没有翻译 帮忙翻译一下
IC identification, pt. 4 (sensors):
Maxim Integrated MAX86902 heart rate sensor (likely)
STMicroelectronics LSM6DS3 3-axis accelerometer/gyroscope
Bosch Sensortec BMP280 pressure sensor
AKM Semiconductor AK09916 3-axis electronic compass
Seiko Instruments S-5712CCDL1-I4T1U hall effect sensor
这个步骤还没有翻译 帮忙翻译一下
Heading south, we hit the modular headphone jack—ready to let the music flow while keeping water out, with a nice sealing gasket.
The USB-C port is new to the Note line—and while reversibility is handy, change is hard. Samsung kindly includes a micro-USB-to-C adapter to keep your cables relevant.
Out goes the daughterboard array! Unlike the one found in the S7, this board used rigid PCB interconnects. This keeps the spidery cable from being flimsy. No one likes flimsy.
IC identification:
Qualcomm QFE2550 antenna tuner
Seiko Instruments S-5712CCDL1-I4T1U hall sensor
Semtech SX9320 proximity sensor (likely)
这个步骤还没有翻译 帮忙翻译一下
If you like tiny heat pipes, Note7 has you covered. This looks like the same "liquid cooling" copper heat dispersal apparatus we pulled from the vanilla S7 and S7 Edge.
Nearby, a note-able amount of glue secures this plastic cover over the S Pen chamber. It's probably there to help ingress-proof the stylus' slot.
Inside, a simple clip grabs the S Pen notches, and a gray rubber bumper protects the nib.
这个步骤还没有翻译 帮忙翻译一下
The volume buttons look pretty complicated, but that doesn't slow us down. Braced with years of experience plucking our unibrows, we dive in, a pair of tweezers in hand.
First out are the microswitches, followed by a reinforcement bracket full of rubber gaskets. Not quite the same, but similar to another waterproofing approach we've seen.
But...what's this? The button covers are oddly trapped within the outer case. We can't pop them out!
- Many components are modular and can be replaced independently.
- Improved cable routing means the charging port board can be removed without disassembling the display.
- The battery can be removed without first ousting the motherboard, but tough adhesive and a glued-on rear panel make replacement very difficult.
- Front and back glass make for double the crackability, and strong adhesive on the rear glass makes it very difficult to gain entry into the device.
- Because of the curved screen, replacing the front glass without destroying the display is probably impossible.
最后的想法
可修复性评分
(10是最容易修复)
由衷感谢以下译者:
43%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
48条评论
would you think its worth upgrading from the s7edge to the Note 7?
Scott Ream - 回复
I would do that.
I would get the iPhone 7 :)
Yeah I would, that stylus is so %#*@ sexy.
okdna -
For sure, note 7 is a beast of a phone, you wont regret it
