跳转到主内容
Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Heat the rear cover: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
  2. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Begin to cut the adhesive: 步骤 3 中的图像 1,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Begin to cut the adhesive: 步骤 3 中的图像 2,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Begin to cut the adhesive: 步骤 3 中的图像 3,3
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Cut along the perimeter of the rear cover: 步骤 4 中的图像 1,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Cut along the perimeter of the rear cover: 步骤 4 中的图像 2,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Cut along the perimeter of the rear cover: 步骤 4 中的图像 3,3
    • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
  5. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the rear cover: 步骤 5 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the rear cover: 步骤 5 中的图像 2,2
    • Lift the rear cover straight up to remove it.
  6. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the wireless charging coil: 步骤 6 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the wireless charging coil: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  7. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the white press connector: 步骤 7 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the white press connector: 步骤 7 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
  8. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the motherboard shield screws: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
  9. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the wireless charging coil: 步骤 9 中的图像 1,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the wireless charging coil: 步骤 9 中的图像 2,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the wireless charging coil: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift up the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
    • Use your fingers to grip the motherboard shield.
  10. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement: 步骤 10 中的图像 3,3
    • Peel the wireless charging coil up and away from the device to remove it.
    • The wireless charging coil is secured to the device with light adhesive.
  11. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the battery: 步骤 11 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the battery: 步骤 11 中的图像 2,2
    • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
  12. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the laser AF sensor: 步骤 12 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Disconnect the laser AF sensor: 步骤 12 中的图像 2,2
    • Use the pointed end of a spudger to pry up the laser AF sensor press connector.
  13. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the earpiece speaker screws: 步骤 13 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 4.0 mm screws securing the earpiece speaker.
  14. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the earpiece speaker: 步骤 14 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the earpiece speaker: 步骤 14 中的图像 2,2
    • Insert the pointed end of a spudger into the hole marked by a small triangle on the right side of the earpiece speaker.
    • Use the spudger to pry up and loosen the earpiece speaker from the frame.
    • The earpiece speaker clips to the frame along the top edge.
  15. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement: 步骤 15 中的图像 2,2
    • Lift and remove the earpiece speaker.
  16. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Front-Facing Camera Cable Disconnection: 步骤 16 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Front-Facing Camera Cable Disconnection: 步骤 16 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the front-facing camera cable from the motherboard.
  17. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Apply isopropyl alcohol: 步骤 17 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Apply isopropyl alcohol: 步骤 17 中的图像 2,2
    • The front-facing camera is glued to the frame.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the open space in the bottom left corner of the front-facing camera.
    • Wait two minutes for the isopropyl alcohol to weaken the adhesive around the front-facing camera.
  18. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Loosen the front-facing camera: 步骤 18 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Loosen the front-facing camera: 步骤 18 中的图像 2,2
    • Insert the pointed end of a spudger into the open space in the bottom left of the front-facing camera.
    • Push the pointed end of the spudger under the front-facing camera.
    • Pry up the front-facing camera to loosen it from the frame.
  19. Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the front-facing camera: 步骤 19 中的图像 1,2 Samsung Galaxy Note20 Ultra Front-Facing Camera Replacement, Remove the front-facing camera: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the front-facing camera.
    • If the front-facing camera doesn't easily lift out of the frame, apply a few more drops of isopropyl alcohol and wait for the adhesive to weaken. Repeat this process as necessary.
    • You can also use the pointed end of a spudger to scrape away some of the adhesive to make the front-facing camera easier to lift out. Remove loose bits of adhesive after this process.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new front-facing camera.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the new front-facing camera to the frame.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
2等其他人完成本指南。
Kyle Smith
于02/01/21注册
49,412 声望
创作了123篇指南
1指南评论
Where can i find a replacement selfie camera?
Kadir Kirubakaran - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 45
总计 3,617
