跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement
你所需要的
    1. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: 步骤 1 中的图像 1,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: 步骤 1 中的图像 2,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement, Micro-USB Port Daughterboard: 步骤 1 中的图像 3,3
      • Use a fingernail or vinyl spudger to easily remove the back cover of the device. Remove the S-Pen, battery, SIM card and MicroSD card (if present).
      询问修复机器人
      添加评论
    2. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 2 中的图像 3,3
      • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 3 中的图像 2,2
      • Heat with a low degree and cut the sticker along the side of touch panel.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 4 中的图像 3,3
      • Free the clasps along the battery slot. And the push the front assembly out from middle housing with effort.
      • We can see the USB board but we can't tear it down directly. Because 1. The USB board flex connector is connecting on the back of the motherboard. 2. If want to remove motherboard, the LCD screen need to be removed at first. 3. The USB board assembly comes with two touch keys together but they are placed under the touch panel.
      • So we have to remove the motherboard and LCD screen at first next.
      询问修复机器人
      添加评论
    5. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 5 中的图像 3,3
      询问修复机器人
      添加评论
    6. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 6 中的图像 2,2
      • Remove two pcs of signal flex cable and two screws which securing USB board and motherboard.
      询问修复机器人
      添加评论
    7. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 7 中的图像 2,2
      • Release all the connectors connecting with motherboard.
      询问修复机器人
      添加评论
    8. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 8 中的图像 2,2
      • Pry up the motherboard and release USB board connector from back.
      询问修复机器人
      添加评论
    9. Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Note 4 Micro-USB Port Daughterboard Replacement: 步骤 9 中的图像 2,2
      • Loosen the touch keys from adhesive at first. And then pry up and remove the USB board finally.
      • It's complicated to do Samsung Galaxy Note 4 USB board assembly replacement. We have to replace the LCD screen and motherboard at first, please be careful.
      添加评论
结论
取消:我没有完成这个指南。
55等其他人完成本指南。
Sophia
于03/25/14注册
43,911 声望
创作了62篇指南
9指南评论
why do you need to take the full LCD off risking it braking. You could just heat the bottom and separate the touch buttons and home button.
Subzero - 回复 分享
Does the daughter board handle the touch fuction of the key or the light only?
George - 回复 分享
charging port from 910C will be suitable to 910F model? Pls answer
Artsiom Tratsiak - 回复 分享
After replacing USB ass'y, my AT&T phone does not recognize the Sim being installed.
Any suggestions?
Dan
Daniel Cameron - 回复 分享
I advice anyone going to attempt this to not take the full LCD off or you will be paying out another £140 for a new screen.
Also save your self time don't take the motherboard out.
ICanFixIt - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 71
总计 75,357
