跳转到主内容
加入维修社区 - 创建账户
SEGA Genesis Flashback Motherboard Replacement
你所需要的
  1. SEGA Genesis Flashback Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
    • Remove this screw with the Phillips #000 screwdriver.
    询问修复机器人
    添加评论
  2. SEGA Genesis Flashback Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
    询问修复机器人
    添加评论
  3. SEGA Genesis Flashback Motherboard Replacement: 步骤 3 中的图像 1,2 SEGA Genesis Flashback Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use your fingers to peel off the four corner rubber feet on the bottom.
    • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
    询问修复机器人
    添加评论
  4. SEGA Genesis Flashback Motherboard Replacement: 步骤 4 中的图像 1,1
    • Flip the case to its upright position.
    • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
    • Remove the back cover from the device.
    • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
    询问修复机器人
    添加评论
  5. SEGA Genesis Flashback Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Unscrew the LED board on the inside of the top plate with the Phillips #000 screwdriver.
    • Note: The top plate is no longer needed for the next steps, so you can feel free to set it aside until reassembly.
    询问修复机器人
    添加评论
  6. SEGA Genesis Flashback Motherboard Replacement: 步骤 6 中的图像 1,2 SEGA Genesis Flashback Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove the five screws circled in the provided picture.
    • The tan board can now detach from the rest of the case, as pictured, but you can feel free to leave it in place for now.
    • CAUTION: Do not disconnect the tan power switch board from the grey ribbon cables.
    询问修复机器人
    添加评论
  7. SEGA Genesis Flashback Motherboard Replacement: 步骤 7 中的图像 1,2 SEGA Genesis Flashback Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the smaller screws located on the green motherboard with the Phillips #000 screwdriver.
    • Remove the two larger screws holding down the game cartridge slot with the Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  8. SEGA Genesis Flashback Motherboard Replacement: 步骤 8 中的图像 1,3 SEGA Genesis Flashback Motherboard Replacement: 步骤 8 中的图像 2,3 SEGA Genesis Flashback Motherboard Replacement: 步骤 8 中的图像 3,3
    • Gently remove the motherboard and the connected tan power switch board from the bottom plate.
    • CAUTION: Be sure not to rip the ribbon cables connecting the motherboard and tan power switch board.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. We have attached photos to assist you in replacing the LED bulb in the correct spot.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G12
4 名成员
创作了10篇指南
1指南评论
Gday!
I recived a Sega HD Flashback 85 for Xmax. When I turned ON the game I have sound on the main menu but not when I played the game.
I went on the at@game to download there firware for the good console since my uptade I don’t have any video game anymore. I rename the file name on my SD Card like the instruction with anysucces. When I installed the SD card with the last firware and turn ON the console it update for ever without rest upload and turn ON the new update.
ERIC GUAY
ERIC GUAY - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 50
总计 2,845
