跳转到主内容
Rival Mini Chopper MC-67BL Power Cord Replacement
Roxanne
Roxanne4 其他贡献者
最后更新于 August 1, 2019
30分钟
困难
This guide will help you remove the power cord and requires the use of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Rival Mini Chopper MC-67BL Power Cord Replacement, Turning Gears: 步骤 1 中的图像 1,2 Rival Mini Chopper MC-67BL Power Cord Replacement, Turning Gears: 步骤 1 中的图像 2,2
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 3 中的图像 1,1
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 4 中的图像 1,1
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 5 中的图像 1,2 Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 6 中的图像 1,1
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 7 中的图像 1,1
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 8 中的图像 1,3 Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 8 中的图像 2,3 Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 8 中的图像 3,3
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Power Cord Replacement, Power Cord: 步骤 9 中的图像 1,1
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 10 中的图像 1,1
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 11 中的图像 1,1
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 12 中的图像 1,2 Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body. The motor and power cable are connected to this panel.
  13. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 13 中的图像 1,1
    • Pull the power cord wires up from underneath the wire hook on the side of the motor.
  14. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 14 中的图像 1,2 Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 14 中的图像 2,2
    • Carefully cut into black wire casing for both wires using a small knife and peel away the black casing.
    • Only cut deep enough to remove the casing.
    • For reassembly you will need black electrical tape to keep the wires from being exposed.
  15. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 15 中的图像 1,1
    • Using a soldering kit, remove the solder for the black power cord from the circuit board.
    • Follow this soldering guide if you need extra help!
  16. Rival Mini Chopper MC-67BL Power Cord Replacement: 步骤 16 中的图像 1,1
    • Use a small knife to cut the copper wires from the bracket holding the black wire and power cord together.
    • For reassembly the copper wires will need to be soldered together.
结论
Roxanne
于10/17/13注册
522 声望
创作了4篇指南
团队
Cal Poly, Team 4-29, Amido Fall 2013 Cal Poly, Team 4-29, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G29
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 416
