跳转到主内容
加入维修社区 - 创建账户
Rival 16131 Toaster Power Wire Repair
你所需要的
  1. Rival 16131 Toaster Power Wire Repair, Shell: 步骤 1 中的图像 1,2 Rival 16131 Toaster Power Wire Repair, Shell: 步骤 1 中的图像 2,2
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    询问修复机器人
    添加评论
  2. Rival 16131 Toaster Power Wire Repair: 步骤 2 中的图像 1,2 Rival 16131 Toaster Power Wire Repair: 步骤 2 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    询问修复机器人
    添加评论
  3. Rival 16131 Toaster Power Wire Repair: 步骤 3 中的图像 1,3 Rival 16131 Toaster Power Wire Repair: 步骤 3 中的图像 2,3 Rival 16131 Toaster Power Wire Repair: 步骤 3 中的图像 3,3
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    询问修复机器人
    添加评论
  4. Rival 16131 Toaster Power Wire Repair: 步骤 4 中的图像 1,1
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    询问修复机器人
    添加评论
  5. Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: 步骤 5 中的图像 1,2 Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: 步骤 5 中的图像 2,2
    • The power wire connects to the toaster in the area highlighted.
    • To free the wire, unscrew the two .5 inch screws, and remove the white brace.
    询问修复机器人
    添加评论
  6. Rival 16131 Toaster Power Wire Repair: 步骤 6 中的图像 1,1
    • To solder the the wire, the circuit board has to be released.
    • To do this, unscrew the .5 inch screw located in the middle of the board.
    • Slowly lift the board up off the toaster, making sure that the red pegs that hold the board in place do not break.
    询问修复机器人
    添加评论
  7. Rival 16131 Toaster Power Wire Repair: 步骤 7 中的图像 1,1
    • To reattach the wire, follow this solder guide.
    • Solder Guide
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Grant Haug
于09/26/12注册
148 声望
创作了4篇指南
团队
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G8
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 2,498
