跳转到主内容
加入维修社区 - 创建账户
Ridgid R86034 LED Replacement
你所需要的
  1. Ridgid R86034 LED Replacement, Housing: 步骤 1 中的图像 1,1
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Make sure the casing is properly oriented onto the housing. Orientation is important here.
    询问修复机器人
    添加评论
  2. Ridgid R86034 LED Replacement: 步骤 2 中的图像 1,2 Ridgid R86034 LED Replacement: 步骤 2 中的图像 2,2
    • Remove the plastic cover with your hands. It should come off fairly easily.
    询问修复机器人
    添加评论
  3. Ridgid R86034 LED Replacement: 步骤 3 中的图像 1,3 Ridgid R86034 LED Replacement: 步骤 3 中的图像 2,3 Ridgid R86034 LED Replacement: 步骤 3 中的图像 3,3
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
    询问修复机器人
    添加评论
  4. Ridgid R86034 LED Replacement: 步骤 4 中的图像 1,2 Ridgid R86034 LED Replacement: 步骤 4 中的图像 2,2
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
    询问修复机器人
    添加评论
  5. Ridgid R86034 LED Replacement: 步骤 5 中的图像 1,1
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger. The housing is easier to remove if you pry from both sides.
    询问修复机器人
    添加评论
  6. Ridgid R86034 LED Replacement: 步骤 6 中的图像 1,2 Ridgid R86034 LED Replacement: 步骤 6 中的图像 2,2
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand. The components should require little force to lift out.
    • Lift out the motor.
    • Follow the wires.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
    询问修复机器人
    添加评论
  7. Ridgid R86034 LED Replacement, LED: 步骤 7 中的图像 1,1
    • Identify the LED light. The LED light is the component with clear casing and has two wires attached, located toward the bottom of the driver.
    询问修复机器人
    添加评论
  8. Ridgid R86034 LED Replacement: 步骤 8 中的图像 1,3 Ridgid R86034 LED Replacement: 步骤 8 中的图像 2,3 Ridgid R86034 LED Replacement: 步骤 8 中的图像 3,3
    • Cut the pink and white wires attached to the LED at a point that is a little more than 1/4 inch from the LED.
    询问修复机器人
    添加评论
  9. Ridgid R86034 LED Replacement: 步骤 9 中的图像 1,1
    • Strip the wires back about 1/4 inch on the LED.
    询问修复机器人
    添加评论
  10. Ridgid R86034 LED Replacement: 步骤 10 中的图像 1,2 Ridgid R86034 LED Replacement: 步骤 10 中的图像 2,2
    • Strip the wires that were connected to the LED on the circuit board to approximately 1/4 inch.
    询问修复机器人
    添加评论
  11. Ridgid R86034 LED Replacement: 步骤 11 中的图像 1,1
    • Solder the new LED striped wires to the wire attached to the circuit board.
    • Wrap the soldered connection with electrical tape, to ensure that the circuit isn't shorted.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Sean Liston
于04/28/15注册
311 声望
创作了2篇指南
团队
Cal Poly, Team 15-5, Amido Spring 2015 Cal Poly, Team 15-5, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 34
总计 1,665
