跳转到主内容
加入维修社区 - 创建账户
Rexing V1P Plus Battery Replacement
你所需要的
    1. Rexing V1P Plus Battery Replacement, Battery: 步骤 1 中的图像 1,3 Rexing V1P Plus Battery Replacement, Battery: 步骤 1 中的图像 2,3 Rexing V1P Plus Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Orient the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. Rexing V1P Plus Battery Replacement: 步骤 2 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 2 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 2 中的图像 3,3
      • Remove the back cover of the device and place it to the side, with care not to strain the connected battery cable.
      • Rotate the device 180 degrees to where the camera is facing you.
      询问修复机器人
      添加评论
    3. Rexing V1P Plus Battery Replacement: 步骤 3 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 3 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 3 中的图像 3,3
      • Remove the two 5 mm screws on either side of the lens using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Rexing V1P Plus Battery Replacement: 步骤 4 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 4 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 4 中的图像 3,3
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      询问修复机器人
      添加评论
    5. Rexing V1P Plus Battery Replacement: 步骤 5 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 5 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 5 中的图像 3,3
      • Remove the two 5 mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    6. Rexing V1P Plus Battery Replacement: 步骤 6 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 6 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 6 中的图像 3,3
      • Carefully remove the plastic frame from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      询问修复机器人
      添加评论
    7. Rexing V1P Plus Battery Replacement: 步骤 7 中的图像 1,3 Rexing V1P Plus Battery Replacement: 步骤 7 中的图像 2,3 Rexing V1P Plus Battery Replacement: 步骤 7 中的图像 3,3
      • Using a soldering iron, remove the two wires connecting the battery to the motherboard.
      • Soldering has the potential to burn you or damage your device. Check out this guide before beginning, take appropriate precautions, and always solder in a well-ventilated area.
      • Once the wires are removed, peel the battery off of the case adhesive.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
4指南评论
Where is it possible to get the replacement battery? Searching on ebay reveals nothing for the information given.
Derek Piper - 回复 分享
Did you find the replacement capacitors?
Jesse Wamberg - 回复 分享
Just realized this appears to be what is known as a 'super capacitor' rather than a battery so it's possible any 5.5V 3.5Farad capacitor will work. The form factor may be an issue though.
Derek Piper - 回复 分享
Replaced the capacitor and it lasts longer but will still lose date and time over night, so probably another component went bad causing drain. Shame.
Robin W - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 60
总计 3,543
