此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
视频概述
要重新组装设备,请按相反顺序执行这些说明。为避免逻辑板损坏,维修完成后,在开机之前,请使用 5 瓦 iPhone 充电器和 USB-C 转 USB-A 线缆将你的 MacBook 连接至低压电源。
12等其他人完成本指南。
2指南评论
Excellent instructions, a big thanks to the author. After completing them the MACBOOK worked OK and then I started to get intermittent problems with the power button and the system bringing the shutdown dialogue without pressing the power button. On closer examination and second removal of the trackpad IPD flex ribbon cable (which also routes keyboard signals to the logic board) the cable came apart at the fold half way along the cable. This cable is very fragile and as mentioned in step 7 you need to be very careful on handling them. In my case I think the cable was fatigued or mechanically damaged where the fold was during manufacture . A replacement cable has been installed and the laptop now works ok.
Mark Timms - 回复 分享
Hi. I've replaced the trackpad after the old one got damaged and started heating up. Macbook turns on perfectly without any trackpad connected, but doesn't even boot when the new trackpad is connected. The motherboard's LED near the battery connector is blinking. Is there something im missing?
