此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
使用本指南更换 Retina MacBook 2015 上的完整 Retina 显示屏组件。
为避免逻辑板损坏,在 MacBook 维修完成后且开机前,请连接至低压电源,使用 5 瓦 iPhone 充电器和 USB-C 转 USB-A 线缆。这些配件未随 MacBook 附带,因此在开始之前请确保已准备好。
你所需要的
视频概述
要重新组装设备,请按相反顺序执行这些说明。为避免逻辑板损坏,在 MacBook 维修完成后且开机前,请连接至低压电源,使用 5 瓦 iPhone 充电器和 USB-C 转 USB-A 线缆。
50等其他人完成本指南。
23指南评论
thank you: very good and clear guiding through
Is there a guide to replace the LCD without replacing the entire shell with housing? Replacements for the LCD only are alt cheaper than buying the entire thing.
MrNewbhero - 回复 分享
MrNewbhero - You probably can replace it without a full clamshell, however, be advised that the front glass acts as a part of the LCD and the layers underneath are just backlight pieces and so on. It's a very difficult job for a DIY
This repair is so nervewreaking. I suggest everyone to take your time and really make sure you're not rushing it, or you may break the connectors, as there's tape on everything almost breaking the connector when you remove the flex cable.
My screen bezel is tearing apart in pieces and got no damage, drop or else, since day 1 I use a UrbanArmor cover, how can I change it, I bought a replacement in eBay.
gerardjulien - 回复 分享
