跳转到主内容
Replacing flash memory to a cisco 837 series router
你所需要的
  1. Replacing flash memory to a cisco 837 series router, Flash memory: 步骤 1 中的图像 1,1
    • CISCO 837 Router
    • CISCO 877 Router
结论
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
另外一个人完成了本指南。
Eneider Colina
于09/20/13注册
2,370 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,478
