跳转到主内容
Repairing Polaroid One-Step 600 Shutter
Kimberly
Kimberly3 其他贡献者
最后更新于 August 29, 2024
1小时
非常困难
This repair guide will show you how to replace the shutter in your Polaroid camera. However, you should be careful with your Polaroid, as the plastic is very fragile.
你所需要的
工具
  • Spudger
    Spudger
  1. Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: 步骤 1 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: 步骤 1 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter, Repairing Polaroid One-Step 600 Shutter: 步骤 1 中的图像 3,3
    • THIS REPAIR GUIDE IS VERY DIFFICULT AND SHOULD ONLY BE FOLLOWED IF YOU HAVE EXPERT MECHANICAL EXPERIENCE.
    • Open the flash/ lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
  2. Repairing Polaroid One-Step 600 Shutter: 步骤 2 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 2 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 2 中的图像 3,3
    • Separate the flash section of the camera from the main body by unhooking the sides.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Repairing Polaroid One-Step 600 Shutter: 步骤 3 中的图像 1,1
    • Open the battery/ cartridge compartment fully.
  4. Repairing Polaroid One-Step 600 Shutter: 步骤 4 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 4 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 4 中的图像 3,3
    • Insert spudger in between face of camera and sides where the four tabs are located.
  5. Repairing Polaroid One-Step 600 Shutter: 步骤 5 中的图像 1,2 Repairing Polaroid One-Step 600 Shutter: 步骤 5 中的图像 2,2
    • Once tabs are released, pull face of camera straight out.
  6. Repairing Polaroid One-Step 600 Shutter: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully use tweezers to remove the spring from the hooks.
    • CAUTION: You may lose the spring if it pops off the hooks.
  7. Repairing Polaroid One-Step 600 Shutter: 步骤 7 中的图像 1,2 Repairing Polaroid One-Step 600 Shutter: 步骤 7 中的图像 2,2
    • Use the spudger to release the latch for the shutter mechanism.
    • Rotate the shutter mechanism clockwise until it stops.
    • If latch was successfully released, shutter mechanism should touch top plastic brace.
  8. Repairing Polaroid One-Step 600 Shutter: 步骤 8 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 8 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 8 中的图像 3,3
    • Release the two tabs that hold lens plate in position.
  9. Repairing Polaroid One-Step 600 Shutter: 步骤 9 中的图像 1,1
    • Remove the lens plate by pulling down, then away from the camera.
  10. Repairing Polaroid One-Step 600 Shutter: 步骤 10 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 10 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 10 中的图像 3,3
    • Remove the shutter mechanism from the camera.
    • Remove black latch piece from the camera.
    • Remove shutter plates from the camera.
  11. Repairing Polaroid One-Step 600 Shutter: 步骤 11 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 11 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 11 中的图像 3,3
    • To replace the shutter pieces in the camera, first make sure they are in the proper order.
    • The shutter piece at the bottom of the first picture belongs on the bottom.
    • The shutter piece in the middle of the first picture goes in the middle (second picture).
    • The shutter piece at the top of the first picture goes on top (third picture).
  12. Repairing Polaroid One-Step 600 Shutter: 步骤 12 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 12 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 12 中的图像 3,3
    • By looking at the first picture, line up the long, skinny slots on the three shutter pieces.
    • In the second picture, notice the pin inside the circle.
    • Line up the slots in the shutters with the pin inside the camera as shown in the third picture.
  13. Repairing Polaroid One-Step 600 Shutter: 步骤 13 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 13 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 13 中的图像 3,3
    • NOTE: The shutter pieces are not included in the first two pictures of this step because they slide around too easily for us to take pictures with them in the camera.
    • Put black plastic piece back into camera, making sure to slide tab into slot (rectangle) and onto the pin (circle).
    • Final assembly for this step should look like the third picture.
  14. Repairing Polaroid One-Step 600 Shutter: 步骤 14 中的图像 1,2 Repairing Polaroid One-Step 600 Shutter: 步骤 14 中的图像 2,2
    • CAUTION: The next two steps are incredibly difficult!
    • First, you must align the tab (circled) with the slot (rectangle).
    • Do not put pieces together until after reading the next step!!!
  15. Repairing Polaroid One-Step 600 Shutter: 步骤 15 中的图像 1,3 Repairing Polaroid One-Step 600 Shutter: 步骤 15 中的图像 2,3 Repairing Polaroid One-Step 600 Shutter: 步骤 15 中的图像 3,3
    • REMINDER: This step is very difficult and may require multiple attempts.
    • Align teal and orange circled tabs from the first picture with the respective teal and orange holes in the shutter pieces.
    • After the shutter mechanism is placed into the camera, make sure all three shutter pieces are attached correctly.
    • NOTE: When correctly attached, the shutter pieces will slide in opposite directions when the shutter mechanism is rotated.
    • To finish putting the Polaroid back together, follow steps 9 through 1 in reverse.
终点
7等其他人完成本指南。
Kimberly
于01/21/10注册
185 声望
撰写一个指南
团队
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G31
4 名成员
创作了7篇指南
1指南评论
I'm pretty sure every type 600 polaroid camera is built the same so this should work with other 600 cameras. I followed this guide for my polaroid 640 land camera and it was exactly the same.
Camdyn - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 130
总计 34,982
