当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Here is the original battery. Three cells surrounded by a soft plastic sheathing
Cut the plastic (I used a utility knife) away.
Now the three cells are clearly visible and the way they are connected in series. Meaning positive from one cell to negative on the next cell. Each cell separated by a rubber insulator
这个步骤还没有翻译 帮忙翻译一下
Top to bottom on this image shows the insulator that is on the top portion of the cells. Next are the old three cells and bottom the new cells.
The contacts on the old cells appear to be spot welded to make the connection.
Separate the connections with either a pair of side cutters or a pair of scissor. This will allow you to remove the insulators.
这个步骤还没有翻译 帮忙翻译一下
Here is the first attempt. Luckily I noticed that I had forgotten to install the rubber insulator before going on to the next cell. Desolder the contacts to rectify this.
Here is the next cell properly prepared.
First two cells, separated by the insulator, soldered together.
这个步骤还没有翻译 帮忙翻译一下
All three cells soldered together, positive to negative end, creating a series connection.
The original battery was wrapped in some soft plastic. I decided to use 1 1/4 inch heat shrink tubing. Black electric tape might work just as well, but I used what I had on hand.
Heatshrink tubing placed over the cells
这个步骤还没有翻译 帮忙翻译一下
I placed a clamp from end to end. This will prevent any exposure to hot parts, will allow movement of the battery and still maintain alignment.
Here is the two speed heatgun I use for my projects.
Simply apply constant heat to the tubing by moving the heatgun along the heatshrink tubing.
这个步骤还没有翻译 帮忙翻译一下
Here is the battery with the heatshrink tubing attached.
Obviously the contacts are being than the connector. (The corrosion visible on the connector was cleaned of during the installation)
Trim the contacts with either a pair of sidecutters, or like in my case, use a pair of scissors.
7等其他人完成本指南。
3条评论
What are the specs on the batteries, and where did you get them? I don’t see any on mine. Thanks!
eBay has the exact set the 4/5 sc sub c are the shorter ones easy to find with connecters already on each end of battery I'm rebuilding mine soon as they come in I'll post results
