跳转到主内容
加入维修社区 - 创建账户
Remington MB4040 Thermal Switch Replacement
你所需要的
    1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 1,3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 2,3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 步骤 1 中的图像 3,3
      • Press the black button below the blade to remove the blade.
      询问修复机器人
      添加评论
    2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 2,2
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      添加评论
    3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 1,3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 2,3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 3,3
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      添加评论
    4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 步骤 4 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 步骤 4 中的图像 2,2
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      添加评论
    5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 步骤 5 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 步骤 5 中的图像 2,2
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      询问修复机器人
      添加评论
    1. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 步骤 6 中的图像 1,2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 步骤 6 中的图像 2,2
      询问修复机器人
      添加评论
    2. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: 步骤 7 中的图像 1,1
      • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
      • Use a low temperature RTV to readhere the thermal switch to the battery.
      • Remove the soldering holding the thermal switch to the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G5
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 3,356
