跳转到主内容
加入维修社区 - 创建账户
Remington MB4040 Zoom Wheel Replacement
你所需要的
  1. Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 步骤 1 中的图像 1,3 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 步骤 1 中的图像 2,3 Remington MB4040 Zoom Wheel Replacement, Remove Blade Assembly: 步骤 1 中的图像 3,3
    • Press the black button below the blade to remove the blade.
    询问修复机器人
    添加评论
  2. Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 1,2 Remington MB4040 Zoom Wheel Replacement, Remove Back Cover Hardware: 步骤 2 中的图像 2,2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
    添加评论
  3. Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 1,3 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 2,3 Remington MB4040 Zoom Wheel Replacement, Remove Front Cover Hardware: 步骤 3 中的图像 3,3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
    添加评论
  4. Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): 步骤 4 中的图像 1,2 Remington MB4040 Zoom Wheel Replacement, Front Cover (cont.): 步骤 4 中的图像 2,2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
    添加评论
  5. Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: 步骤 5 中的图像 1,2 Remington MB4040 Zoom Wheel Replacement, Blade Button Removal: 步骤 5 中的图像 2,2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
    询问修复机器人
    添加评论
  6. Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: 步骤 6 中的图像 1,2 Remington MB4040 Zoom Wheel Replacement, Remove screws attaching the zoom wheel: 步骤 6 中的图像 2,2
    • Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
    询问修复机器人
    添加评论
  7. Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 步骤 7 中的图像 1,3 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 步骤 7 中的图像 2,3 Remington MB4040 Zoom Wheel Replacement, Remove Zoom Wheel Assembly: 步骤 7 中的图像 3,3
    • Remove zoom wheel assembly from housing using fingers.
    • Gently remove zoom wheel assembly because the red and black wires are attached and can easily be broken.
    • This assembly also houses the motor.
    • Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
    • When reassembling, make sure the pins on the slider are aligned inside the grooves of the wheel.
    询问修复机器人
    添加评论
  8. Remington MB4040 Zoom Wheel Replacement, Wheel removal: 步骤 8 中的图像 1,3 Remington MB4040 Zoom Wheel Replacement, Wheel removal: 步骤 8 中的图像 2,3 Remington MB4040 Zoom Wheel Replacement, Wheel removal: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G5
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 23
总计 3,690
