跳转到主内容
加入维修社区 - 创建账户
Redmi Note 9 Pro Loudspeaker Replacement
你所需要的
  1. Redmi Note 9 Pro Loudspeaker Replacement, Heat the rear glass: 步骤 1 中的图像 1,1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: 步骤 3 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: 步骤 3 中的图像 2,2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: 步骤 4 中的图像 1,3 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: 步骤 4 中的图像 2,3 Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: 步骤 4 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Redmi Note 9 Pro Loudspeaker Replacement: 步骤 5 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement: 步骤 5 中的图像 2,2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Redmi Note 9 Pro Loudspeaker Replacement: 步骤 6 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  7. Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: 步骤 7 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: 步骤 7 中的图像 2,2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the motherboard cover screws: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
  9. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: 步骤 9 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: 步骤 9 中的图像 2,2
    • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
    • Flip the opening pick sideways to pry up the motherboard cover.
  10. Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: 步骤 10 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  11. Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: 步骤 11 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: 步骤 11 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  12. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the loudspeaker assembly screws: 步骤 12 中的图像 1,1
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
  13. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: 步骤 13 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: 步骤 13 中的图像 2,2
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the battery.
    • Use your opening pick to pry up the loudspeaker assembly.
  14. Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: 步骤 14 中的图像 1,2 Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: 步骤 14 中的图像 2,2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
250,524 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,046篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 123
总计 5,343
