跳转到主内容
Razer Viper Mini Scroll Wheel Replacement
Addison
Addison 另一个贡献者
最后更新于 September 1, 2023
10分钟
简单
社区贡献指南
The Razer Viper Mini may experience faulty scroll wheel operation, such as a stuck wheel or having a non-functional scroll wheel click. This guide will show you how to access the scroll wheel for cleaning or replacement.
你所需要的
工具
查看更多...
  1. Razer Viper Mini Scroll Wheel Replacement, Remove Information Sticker: 步骤 1 中的图像 1,2 Razer Viper Mini Scroll Wheel Replacement, Remove Information Sticker: 步骤 1 中的图像 2,2
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Make sure to unplug the mouse before doing anything.
    • Turn the Mouse Over so the bottom is facing up.
    • Remember to take a photo of your serial number or write it down
    • Take off the information sticker and the plastic cover from the bottom of the mouse.
  2. Razer Viper Mini Scroll Wheel Replacement, Remove Baseplate Screws: 步骤 2 中的图像 1,2 Razer Viper Mini Scroll Wheel Replacement, Remove Baseplate Screws: 步骤 2 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the three 2 mm screws from the bottom of the mouse.
    • When removing the screws, unscrew them each slightly and consecutively until you can pull them out with your hands.
  3. Razer Viper Mini Scroll Wheel Replacement, Detach backplate: 步骤 3 中的图像 1,3 Razer Viper Mini Scroll Wheel Replacement, Detach backplate: 步骤 3 中的图像 2,3 Razer Viper Mini Scroll Wheel Replacement, Detach backplate: 步骤 3 中的图像 3,3
    • Use the plastic spudger to gently lift the backplate from the mouse shell.
    • Insert the spudger into the bottom back of the mouse and slowly move it around the mouse to release the backplate.
    • Do not try to push or jab the mouse with the plastic spudger with a large amount of force, this can damage the plating of your mouse.
  4. Razer Viper Mini Scroll Wheel Replacement, Remove shell: 步骤 4 中的图像 1,2 Razer Viper Mini Scroll Wheel Replacement, Remove shell: 步骤 4 中的图像 2,2
    • Use the plastic spudger once again to remove the top shell of the mouse.
    • It is similar to the previous step, as you have to pry the plastic spudger gently into the bottom of the mouse and move it slowly inwards and upwards to release the shell.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the cable.
  5. Razer Viper Mini Scroll Wheel Replacement, Disconnect the Ribbon Connector: 步骤 5 中的图像 1,2 Razer Viper Mini Scroll Wheel Replacement, Disconnect the Ribbon Connector: 步骤 5 中的图像 2,2
    • Disconnect the ribbon connector between the motherboard and the USB cable by squeezing the connector and pulling up.
    • Pulling too hard could damage the wire connections.
    • Pulling by the ribbon instead of the connector can dislocate the wires.
  6. Razer Viper Mini Scroll Wheel Replacement, Unscrew Motherboard from Case: 步骤 6 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove 2 5.5 and 3 2.5 mm screws.
  7. Razer Viper Mini Scroll Wheel Replacement, Remove Motherboard: 步骤 7 中的图像 1,1
    • Remove the motherboard by grasping the sides and gently pulling upward.
  8. Razer Viper Mini Scroll Wheel Replacement, Remove Scroll Wheel from case: 步骤 8 中的图像 1,2 Razer Viper Mini Scroll Wheel Replacement, Remove Scroll Wheel from case: 步骤 8 中的图像 2,2
    • Remove the scroll wheel from the socket by pulling to the right.
    • Pulling too hard could damage the scroll wheel connector.
结论
5等其他人完成本指南。
Addison
于08/30/19注册
3,024 声望
创作了17篇指南
2指南评论
When we remove the scroll wheel, can we get the scroll wheel for it?
مسعود مهنانی - 回复
Kevin Lee Pagulayan - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 65
过去 30 天: 256
总计 15,847
