跳转到主内容
加入维修社区 - 创建账户
Razer DeathAdder V3 Pro Encoder Replacement
你所需要的
  1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 步骤 1 中的图像 1,3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 步骤 1 中的图像 2,3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 步骤 1 中的图像 3,3
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    询问修复机器人
    添加评论
  2. Razer DeathAdder V3 Pro Encoder Replacement: 步骤 2 中的图像 1,2 Razer DeathAdder V3 Pro Encoder Replacement: 步骤 2 中的图像 2,2
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    询问修复机器人
    添加评论
  3. Razer DeathAdder V3 Pro Encoder Replacement: 步骤 3 中的图像 1,2 Razer DeathAdder V3 Pro Encoder Replacement: 步骤 3 中的图像 2,2
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    询问修复机器人
    添加评论
  4. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: 步骤 4 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
    • Unplug the battery from its connection on the right side.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    询问修复机器人
    添加评论
  5. Razer DeathAdder V3 Pro Encoder Replacement: 步骤 5 中的图像 1,1
    • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
    询问修复机器人
    添加评论
  6. Razer DeathAdder V3 Pro Encoder Replacement: 步骤 6 中的图像 1,2 Razer DeathAdder V3 Pro Encoder Replacement: 步骤 6 中的图像 2,2
    • Wear eye protection.
    • Take care not to damage the PCB or any other components.
    • Use a pair of flush cutters to cut the legs of the encoder.
    • Desolder the legs of the 15 mm encoder on the underside of the PCB.
    • Remove the encoder.
    • Always solder in a well ventilated area.
    • Use a solder sucker to remove any excess solder.
    询问修复机器人
    添加评论
  7. Razer DeathAdder V3 Pro Encoder Replacement: 步骤 7 中的图像 1,1
    • Press the new 15 mm encoder into place
    • If the encoder does not fit properly, clean the old solder more thoroughly.
    • Solder the new 15 mm encoder into place.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Nicholas
于09/24/25注册
453 声望
创作了4篇指南
团队
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025 的会员
TTU-JOHANSEN-F25S2G5
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 57
过去 30 天: 268
总计 1,330
