跳转到主内容
加入维修社区 - 创建账户
Razer Blade 15" (2018) RAM Replacement
你所需要的
    1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      询问修复机器人
      添加评论
    1. Razer Blade 15" (2018) RAM Replacement, Unfasten the back cover: 步骤 2 中的图像 1,1
      • Rotate your laptop so the screen hinge is farthest from you.
      • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
      询问修复机器人
      添加评论
    2. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
      • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      询问修复机器人
      添加评论
    3. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 步骤 4 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 步骤 4 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 步骤 4 中的图像 3,3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      • Insert your pick up to 10 mm (0.4 in) deep.
      询问修复机器人
      添加评论
    4. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 步骤 5 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 步骤 5 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 步骤 5 中的图像 3,3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      询问修复机器人
      添加评论
    5. Razer Blade 15" (2018) RAM Replacement, Free the front edge: 步骤 6 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: 步骤 6 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: 步骤 6 中的图像 3,3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
      询问修复机器人
      添加评论
    6. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 步骤 7 中的图像 3,3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
      询问修复机器人
      添加评论
    1. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: 步骤 8 中的图像 1,2 Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: 步骤 8 中的图像 2,2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
      询问修复机器人
      添加评论
    2. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 步骤 9 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 步骤 9 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
      询问修复机器人
      添加评论
    3. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 步骤 10 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 步骤 10 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 步骤 10 中的图像 3,3
      • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
      询问修复机器人
      添加评论
    1. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 步骤 11 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 步骤 11 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 步骤 11 中的图像 3,3
      • Two metal arms secure the left and right edges of each RAM stick.
      • Push the lower RAM stick's metal arms outward to disengage them.
      • Remove the RAM stick.
      • During reassembly, insert the RAM stick at a 30-degree angle, then push straight down to engage the metal arms.
      询问修复机器人
      添加评论
    2. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 步骤 12 中的图像 1,3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 步骤 12 中的图像 2,3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 步骤 12 中的图像 3,3
      • Disengage the upper RAM stick's arms and remove the RAM.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Clay Eickemeyer
于09/19/22注册
106,001 声望
创作了472篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了40,667篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 35
总计 700
