跳转到主内容
Raidmax Alpha Case Graphics Card Replacement
Julia Strecker
Julia Strecker2 其他贡献者
最后更新于 March 9, 2023
15 - 30 分钟
中等
The purpose of this guide is to instruct a user on how to replace a computer graphics card in a Raidmax Alpha case. A computer graphics card is a piece of computer hardware that produces the image seen on a monitor. This card renders an image to the monitor by converting data into a signal the monitor can understand. If this card is not present in a computer, the graphics will not be displayed. Using a better quality graphics card can give a better image that is output on the screen.
The user will need to have some basic background information on how to replace computer parts. If the steps to recycle the power in the computer are not followed, there could be residual current left that could be dangerous to the user.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 步骤 1 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 步骤 1 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement, Graphics Card: 步骤 1 中的图像 3,3
    • Turn off the computer and the power supply to the computer.
  2. Raidmax Alpha Case Graphics Card Replacement: 步骤 2 中的图像 1,2 Raidmax Alpha Case Graphics Card Replacement: 步骤 2 中的图像 2,2
    • Recycle the power in the computer by pressing the power button on and off again. This removes any remaining current to the computer.
  3. Raidmax Alpha Case Graphics Card Replacement: 步骤 3 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 3 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 3 中的图像 3,3
    • Access the glass side panel by turning the back of the case to the left when looking at it from the front.
  4. Raidmax Alpha Case Graphics Card Replacement: 步骤 4 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 4 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 4 中的图像 3,3
    • Remove the two screws on the glass side panel. These are thumb screws so they can simply be removed by twisting them to the left.
  5. Raidmax Alpha Case Graphics Card Replacement: 步骤 5 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 5 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 5 中的图像 3,3
    • Carefully slide the glass panel to the left and then pull it off to remove it.
  6. Raidmax Alpha Case Graphics Card Replacement: 步骤 6 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 6 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 6 中的图像 3,3
    • Tilt the case backward and lay it on its backside. This is done so the card will not pull down when being removed.
  7. Raidmax Alpha Case Graphics Card Replacement: 步骤 7 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 7 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 7 中的图像 3,3
    • Undo the power connection to the card. Push the clip on the connector and pull the cable up.
  8. Raidmax Alpha Case Graphics Card Replacement: 步骤 8 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 8 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 8 中的图像 3,3
    • Remove three 6.3 mm screws to the card located on the left side of the case using a Phillips #2 screwdriver.
  9. Raidmax Alpha Case Graphics Card Replacement: 步骤 9 中的图像 1,2 Raidmax Alpha Case Graphics Card Replacement: 步骤 9 中的图像 2,2
    • Push down the clip to the motherboard circled in red.
  10. Raidmax Alpha Case Graphics Card Replacement: 步骤 10 中的图像 1,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 10 中的图像 2,3 Raidmax Alpha Case Graphics Card Replacement: 步骤 10 中的图像 3,3
    • Carefully grip the old graphics card with two hands and lift it out of the case.
结论
7等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 98
总计 3,803
