跳转到主内容
加入维修社区 - 创建账户
Press Connector Cover Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Press Connector Cover Removal, Apply tape to a cracked screen: 步骤 1 中的图像 1,3 Press Connector Cover Removal, Apply tape to a cracked screen: 步骤 1 中的图像 2,3 Press Connector Cover Removal, Apply tape to a cracked screen: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. Press Connector Cover Removal, Opening Procedure: 步骤 2 中的图像 1,1
  3. Press Connector Cover Removal: 步骤 3 中的图像 1,3 Press Connector Cover Removal: 步骤 3 中的图像 2,3 Press Connector Cover Removal: 步骤 3 中的图像 3,3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  4. Press Connector Cover Removal: 步骤 4 中的图像 1,2 Press Connector Cover Removal: 步骤 4 中的图像 2,2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. Press Connector Cover Removal: 步骤 5 中的图像 1,1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. Press Connector Cover Removal: 步骤 6 中的图像 1,3 Press Connector Cover Removal: 步骤 6 中的图像 2,3 Press Connector Cover Removal: 步骤 6 中的图像 3,3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. Press Connector Cover Removal: 步骤 7 中的图像 1,3 Press Connector Cover Removal: 步骤 7 中的图像 2,3 Press Connector Cover Removal: 步骤 7 中的图像 3,3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. Press Connector Cover Removal: 步骤 8 中的图像 1,2 Press Connector Cover Removal: 步骤 8 中的图像 2,2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. Press Connector Cover Removal: 步骤 9 中的图像 1,1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. Press Connector Cover Removal: 步骤 10 中的图像 1,3 Press Connector Cover Removal: 步骤 10 中的图像 2,3 Press Connector Cover Removal: 步骤 10 中的图像 3,3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. Press Connector Cover Removal: 步骤 11 中的图像 1,3 Press Connector Cover Removal: 步骤 11 中的图像 2,3 Press Connector Cover Removal: 步骤 11 中的图像 3,3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. Press Connector Cover Removal: 步骤 12 中的图像 1,3 Press Connector Cover Removal: 步骤 12 中的图像 2,3 Press Connector Cover Removal: 步骤 12 中的图像 3,3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a third pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the third pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. Press Connector Cover Removal: 步骤 13 中的图像 1,2 Press Connector Cover Removal: 步骤 13 中的图像 2,2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. Press Connector Cover Removal: 步骤 14 中的图像 1,1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  15. Press Connector Cover Removal: 步骤 15 中的图像 1,3 Press Connector Cover Removal: 步骤 15 中的图像 2,3 Press Connector Cover Removal: 步骤 15 中的图像 3,3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. Press Connector Cover Removal: 步骤 16 中的图像 1,3 Press Connector Cover Removal: 步骤 16 中的图像 2,3 Press Connector Cover Removal: 步骤 16 中的图像 3,3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. Press Connector Cover Removal: 步骤 17 中的图像 1,1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. Press Connector Cover Removal: 步骤 18 中的图像 1,3 Press Connector Cover Removal: 步骤 18 中的图像 2,3 Press Connector Cover Removal: 步骤 18 中的图像 3,3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. Press Connector Cover Removal: 步骤 19 中的图像 1,2 Press Connector Cover Removal: 步骤 19 中的图像 2,2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. Press Connector Cover Removal: 步骤 20 中的图像 1,2 Press Connector Cover Removal: 步骤 20 中的图像 2,2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. Press Connector Cover Removal: 步骤 21 中的图像 1,2 Press Connector Cover Removal: 步骤 21 中的图像 2,2
    • Slide the pick around the lower left edge of the iPad.
  22. Press Connector Cover Removal: 步骤 22 中的图像 1,3 Press Connector Cover Removal: 步骤 22 中的图像 2,3 Press Connector Cover Removal: 步骤 22 中的图像 3,3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. Press Connector Cover Removal: 步骤 23 中的图像 1,3 Press Connector Cover Removal: 步骤 23 中的图像 2,3 Press Connector Cover Removal: 步骤 23 中的图像 3,3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. Press Connector Cover Removal, Hold the screen perpendicular: 步骤 24 中的图像 1,1
    • To avoid stressing any cables, hold the screen perpendicular to the frame.
  25. Press Connector Cover Removal, Remove the display cable bracket: 步骤 25 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Continue to hold the screen perpendicular during this step.
    • Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
  26. Press Connector Cover Removal, Reposition the screen: 步骤 26 中的图像 1,1
    • You'll need to reposition the screen to access the bottom side of the display cable bracket.
    • Lower the screen to about 30 degrees above the frame.
  27. Press Connector Cover Removal, Disconnect the battery: 步骤 27 中的图像 1,2 Press Connector Cover Removal, Disconnect the battery: 步骤 27 中的图像 2,2
    • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
    • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
  28. Press Connector Cover Removal, Rotate the display cable bracket: 步骤 28 中的图像 1,3 Press Connector Cover Removal, Rotate the display cable bracket: 步骤 28 中的图像 2,3 Press Connector Cover Removal, Rotate the display cable bracket: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    • The display cable bracket is secured by a clip under the edge of the frame.
    • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
    • Rotate the display cable bracket toward the battery.
    • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
  29. Press Connector Cover Removal, Disconnect the display press connectors: 步骤 29 中的图像 1,2 Press Connector Cover Removal, Disconnect the display press connectors: 步骤 29 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
  30. Press Connector Cover Removal: 步骤 30 中的图像 1,3 Press Connector Cover Removal: 步骤 30 中的图像 2,3 Press Connector Cover Removal: 步骤 30 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the second and third display press connectors.
  31. Press Connector Cover Removal, Remove the screen: 步骤 31 中的图像 1,1
    • Lift and remove the screen.
  32. Press Connector Cover Removal, Screen reassembly information: 步骤 32 中的图像 1,3 Press Connector Cover Removal, Screen reassembly information: 步骤 32 中的图像 2,3 Press Connector Cover Removal, Screen reassembly information: 步骤 32 中的图像 3,3
    • During reassembly, remove any remaining adhesive and residue from the perimeters of the frame and the screen. Then, apply new adhesive to secure the screen to the frame.
    • Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
    • Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
  33. Press Connector Cover Removal, Lift the tape: 步骤 33 中的图像 1,2 Press Connector Cover Removal, Lift the tape: 步骤 33 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift up the tape covering the press connector cover screws.
    • Lift the tape slowly to avoid ripping it. You can pry it off of the press connector cover by pulling it up in multiple places if needed.
  34. Press Connector Cover Removal, Remove the three Phillips screws: 步骤 34 中的图像 1,1
    • Use a Phillips screwdriver to remove the three screws securing the press connector cover:
    • One 1.9 mm screw
    • Two 1.3 mm screws
  35. Press Connector Cover Removal, Remove the press connector cover: 步骤 35 中的图像 1,2 Press Connector Cover Removal, Remove the press connector cover: 步骤 35 中的图像 2,2
    • Use a pair of tweezers to remove the press connector cover.
结论
Kyle Smith
于02/01/21注册
51,092 声望
创作了123篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 183
