PowerShot G7 X Mark II Top Cover Button Panel Replacement
简介
转到步骤 1This guide will show you how to replace the entire top cover and button assembly on the top of the camera This guide is useful if the buttons have been damaged.
Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
4等其他人完成本指南。
1指南评论
We followed this guide but now my camera will not turn on. The little green light by the play button will light up but thats it. Any idea what went wrong?
