简介
If you need to replace the fan of your Porter-Cable PCE211 impact wrench, follow this guide.
If the fan has begun to malfunction or has totally failed, the tool will start to heat up quickly and this can easily cause damage to the other internal components. For additional information or troubleshooting your impact wrench, refer to the troubleshooting guide.
Before beginning this repair, be sure to turn off the device and unplug it from the outlet.
你所需要的
Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
