跳转到主内容
PlayStation Vita Left Shoulder Button Replacement
Brittany McCrigler
Brittany McCrigler5 其他贡献者
最后更新于 June 19, 2024
20 - 30 分钟
中等
This guide takes you through the process of installing the left shoulder button on the PlayStation Vita.
你所需要的
配件
工具
查看更多...
  1. PlayStation Vita Left Shoulder Button Replacement, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita Left Shoulder Button Replacement, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Shoulder Button Replacement: 步骤 2 中的图像 1,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 2 中的图像 2,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Shoulder Button Replacement: 步骤 3 中的图像 1,2 PlayStation Vita Left Shoulder Button Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Shoulder Button Replacement: 步骤 4 中的图像 1,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 4 中的图像 2,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Shoulder Button Replacement: 步骤 5 中的图像 1,2 PlayStation Vita Left Shoulder Button Replacement: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Left Shoulder Button Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Shoulder Button Replacement: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Left Shoulder Button Replacement: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 步骤 9 中的图像 1,3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 步骤 9 中的图像 2,3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: 步骤 9 中的图像 3,3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Shoulder Button Replacement: 步骤 10 中的图像 1,2 PlayStation Vita Left Shoulder Button Replacement: 步骤 10 中的图像 2,2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Shoulder Button Replacement: 步骤 11 中的图像 1,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 11 中的图像 2,3 PlayStation Vita Left Shoulder Button Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Shoulder Button Replacement: 步骤 12 中的图像 1,2 PlayStation Vita Left Shoulder Button Replacement: 步骤 12 中的图像 2,2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
结论
5等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,769 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,581篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 94
总计 13,524
