跳转到主内容
Plantronics Headphone Battery Replacement
jo fixit
jo fixit4 其他贡献者
最后更新于 June 19, 2024
没有估计
中等
Nuance Dragon Plantronics Calisto B70 or Plantronics Calisto Pro B70 are used as examples here: “Make your Dragon listen to you again”.
Disclaimer: All work and opening of the equipment is on your own responsibility and risk!
After 10 years of use, the battery does not last long enough. A new battery and some skilled work on the delicate device end up with a fully functioning headset again.
  1. Plantronics Headphone Battery Replacement, Battery: 步骤 1 中的图像 1,2 Plantronics Headphone Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • The red markings show the positions of breaking/fixing points inside the case, which are slightly glued. Nevertheless, the case can be opened without too much damage using a small, sharp screwdriver. The fix at the back of the headset at position 1 is clipped inside the case, rather than glued (see clip at steps 4 and 11).
  2. Plantronics Headphone Battery Replacement: 步骤 2 中的图像 1,1
    • Use a small, sharp screwdriver to open the case carefully, starting at position 1.
  3. Plantronics Headphone Battery Replacement: 步骤 3 中的图像 1,1
    • You will likely damage the case a little bit. First, open 2a and 2b with a sharp screwdriver.
    • Then, open 3a and 3b with a sharp screwdriver.
  4. Plantronics Headphone Battery Replacement: 步骤 4 中的图像 1,2 Plantronics Headphone Battery Replacement: 步骤 4 中的图像 2,2
    • Very carefully open 4 with a sharp screwdriver.
    • The case is glued and sealed with foam at 4.
    • Remove the foam from the case.
  5. Plantronics Headphone Battery Replacement: 步骤 5 中的图像 1,1
    • The two loudspeaker wires are quite delicate, so take special care with them as you continue to work on the headphones in future steps.
  6. Plantronics Headphone Battery Replacement, Power connector: 步骤 6 中的图像 1,1
    • If the power connector is glued into the case, then de-soldering it is the easiest solution. If it is not glued, then de-soldering is not necessary.
  7. Plantronics Headphone Battery Replacement: 步骤 7 中的图像 1,1
    • Be sure to remove assembly carefully.
    • Be careful with loudspeaker wires.
  8. Plantronics Headphone Battery Replacement: 步骤 8 中的图像 1,1
    • De-solder the battery positive (+) and negative (-) cables from the circuit board.
  9. Plantronics Headphone Battery Replacement, Battery: 步骤 9 中的图像 1,1
    • If the battery is glued with a piece of foam, then cut it with sharp knife.
    • Take care not to puncture the battery!
  10. Plantronics Headphone Battery Replacement, Replacement: 步骤 10 中的图像 1,3 Plantronics Headphone Battery Replacement, Replacement: 步骤 10 中的图像 2,3 Plantronics Headphone Battery Replacement, Replacement: 步骤 10 中的图像 3,3
    • Exchange the battery with the new replacement.
    • The replacement battery in the picture worked perfectly for the Plantronics B70.
    • Cut and prepare the replacement battery cables for soldering.
    • Solder the new battery to plus (red cable) and minus (black cable).
  11. Plantronics Headphone Battery Replacement: 步骤 11 中的图像 1,3 Plantronics Headphone Battery Replacement: 步骤 11 中的图像 2,3 Plantronics Headphone Battery Replacement: 步骤 11 中的图像 3,3
    • Fix the new battery onto the foam and place it in the center of the position, which is marked by a white line.
    • Carefully put everything back into position. Re-solder the power connector, if it had to be de-soldered before. Fix it back into the round hole.
    • Close the case with the clip 1. The black and silver case can be fixed best using some transparent tape around the case.
结论
Test loading the new battery as usual.
另外一个人完成了本指南。
jo fixit
于04/14/19注册
538 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 44
总计 818
