跳转到主内容
加入维修社区 - 创建账户
Photive Rain Battery Replacement
你所需要的
    1. Photive Rain Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Turn the speaker off before disassembling.
      • Remove the suction cup from its groove by twisting and turning it.
      询问修复机器人
      添加评论
    2. Photive Rain Battery Replacement: 步骤 2 中的图像 1,1
      • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
      • Remove back panel
      询问修复机器人
      添加评论
    1. Photive Rain Battery Replacement, Battery: 步骤 3 中的图像 1,2 Photive Rain Battery Replacement, Battery: 步骤 3 中的图像 2,2
      • Remove the plastic cover in front of the battery slot.
      • Unscrew all the 8.5mm screws that hold the cover to the slot.
      • Separate the battery from the back panel as shown in photograph 3.
      • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
      询问修复机器人
      添加评论
    2. Photive Rain Battery Replacement: 步骤 4 中的图像 1,1
      • Remove the battery from the motherboard.
      • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
      • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G4
3 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 28
总计 829
