跳转到主内容
Philips Sonicare FlexCare Spring Replacement
Joanna Moraza
Joanna Moraza4 其他贡献者
最后更新于 June 2, 2023
5分钟
中等
详尽分析
更好的介绍
This guide will help you replace the spring in your Philips Sonicare FlexCare toothbrush.
你所需要的
工具
  1. Philips Sonicare FlexCare Spring Replacement, Spring: 步骤 1 中的图像 1,1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Spring Replacement: 步骤 2 中的图像 1,2 Philips Sonicare FlexCare Spring Replacement: 步骤 2 中的图像 2,2
    • Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
  3. Philips Sonicare FlexCare Spring Replacement: 步骤 3 中的图像 1,1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
  4. Philips Sonicare FlexCare Spring Replacement: 步骤 4 中的图像 1,1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Spring Replacement: 步骤 5 中的图像 1,1
    • Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
  6. Philips Sonicare FlexCare Spring Replacement: 步骤 6 中的图像 1,1
    • Remove the spring from the rubber ring and replace it with the new spring.
结论
4等其他人完成本指南。
Joanna Moraza
于04/14/15注册
1,886 声望
创作了2篇指南
团队
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G6
4 名成员
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 51
总计 5,578
