跳转到主内容
Philips Sonicare DiamondClean Metal Brush Connector Replacement
Zachary Bertrand
Zachary Bertrand3 其他贡献者
最后更新于 May 7, 2024
1小时
中等
不正确的工具
更好的介绍
你所需要的
配件
工具
查看更多...
  1. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 步骤 1 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 步骤 1 中的图像 2,2
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 2 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 2 中的图像 2,2
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 4 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 4 中的图像 2,2
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Metal Brush Connector Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver to remove the screw at the base of the metal head.
  6. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
  7. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 7 中的图像 1,1
    • Gently pull the metal head from the innards.
结论
9等其他人完成本指南。
团队
IUPUI, Team S22-G1, Bayer Fall 2017 IUPUI, Team S22-G1, Bayer Fall 2017 的会员
IUPUI-BAYER-F17S22G1
4 名成员
创作了9篇指南
8条评论
Great guide - but where is a good source for replacement parts?
Christian Zischek - 回复
Ordered replacement part, came within 3 days at ebay. Didn’t have to replace the soft rubber inlet parts, only the connector.
Piece of cake, exchange of battery seems more labourous, but the brush still works for two weeks, so we postpone this job.
Emilio - 回复
Gut beschrieben, aber wo bekomme ich eine neue Antriebsachse?
Beste Grüße - pechi606
Walter P - 回复
Z.B. direkt aus China : ebay
VauWeh -
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
tim belina - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 65
过去 30 天: 261
总计 20,773
