跳转到主内容
Philips PD9000 37 Disk Drive Replacement
Julia Sheremet
Julia Sheremet5 其他贡献者
最后更新于 May 7, 2024
5秒 - 10分钟
简单
If the disk isn't reading you may need to replace the drive in order to continue to play disks. To do this, you will be required to remove the outside casing on the player.
你所需要的
工具
查看更多...
  1. Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 步骤 1 中的图像 1,3 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 步骤 1 中的图像 2,3 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 步骤 1 中的图像 3,3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Philips PD9000 37 Disk Drive Replacement: 步骤 2 中的图像 1,2 Philips PD9000 37 Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 Disk Drive Replacement: 步骤 3 中的图像 1,3 Philips PD9000 37 Disk Drive Replacement: 步骤 3 中的图像 2,3 Philips PD9000 37 Disk Drive Replacement: 步骤 3 中的图像 3,3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 Disk Drive Replacement: 步骤 4 中的图像 1,3 Philips PD9000 37 Disk Drive Replacement: 步骤 4 中的图像 2,3 Philips PD9000 37 Disk Drive Replacement: 步骤 4 中的图像 3,3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
  5. Philips PD9000 37 Disk Drive Replacement, Disk Drive: 步骤 5 中的图像 1,2 Philips PD9000 37 Disk Drive Replacement, Disk Drive: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the Tweezers from the iFixit repair tools, pull the two white plastic connectors that connect the disk drive to the motherboard off detaching the disk drive from the motherboard.
  6. Philips PD9000 37 Disk Drive Replacement: 步骤 6 中的图像 1,1
    • Grab the sides of the disk drive and gently pull straight up to detach the disk drive.
    • The white ribbon is not connected to the actual drive, so it can be ignored.
结论
2等其他人完成本指南。
1指南评论
Hi! Where I can buy the Philips PD9000 37 Disk Drive Replacement because I can´t find it... Thanks
Eduardo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 4,044
