跳转到主内容
Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement
ilan
ilan3 其他贡献者
最后更新于 July 15, 2024
3分钟
中等
If the beard comb does not move, there may be a problem with the inside of the zoom lock ring, and the zoom lock precision notch may need to be replaced. Follow this guide to replace the zoom lock precision notch.
你所需要的
工具
  1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Front and Back Panels: 步骤 1 中的图像 1,1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 2 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 2 中的图像 2,2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 3 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 3 中的图像 2,2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 4 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 4 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 4 中的图像 3,3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 5 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 5 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 5 中的图像 3,3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 6 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 6 中的图像 2,2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 7 中的图像 1,1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 8 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 8 中的图像 2,2
  9. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Zoom Lock Precision Notch: 步骤 9 中的图像 1,1
    • Locate the zoom lock precision notch in the back panel of the Beardtrimmer
  10. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 10 中的图像 1,1
    • Set the zoom lock wheel to the lowest setting
  11. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 11 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 11 中的图像 2,2
    • Rotate the trimmer so that the motor is facing you.
    • Now gently push down the zoom lock wheel until the white button is not showing.
  12. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 12 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 12 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: 步骤 12 中的图像 3,3
    • Rotate the beardtrimmer again so that the battery is facing you.
    • With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
结论
ilan
于09/03/15注册
173 声望
撰写一个指南
团队
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G2
4 名成员
创作了14篇指南
1指南评论
How to fix charging wire to the plate?
Kartik Gusain - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 4,610
