跳转到主内容
Philips DC320 37 Headphone or Power Jack Replacement
Graham Rolph
Graham Rolph5 其他贡献者
最后更新于 January 28, 2014
10 - 20 分钟
简单
特色学生指南
动态照片拍摄
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Philips DC320 37 Headphone or Power Jack Replacement, Docking entertainment system: 步骤 1 中的图像 1,1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: 步骤 2 中的图像 1,1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: 步骤 4 中的图像 1,3 Philips DC320 37 Headphone or Power Jack Replacement: 步骤 4 中的图像 2,3 Philips DC320 37 Headphone or Power Jack Replacement: 步骤 4 中的图像 3,3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: 步骤 5 中的图像 1,1
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: 步骤 6 中的图像 1,1
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: 步骤 7 中的图像 1,1
    • Separate the white suport bracket from the headphone/power electronics board.
结论
Graham Rolph
于04/18/13注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G48
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,292
