跳转到主内容
Petcube Play 2 Speaker Replacement
你所需要的
  1. Petcube Play 2 Speaker Replacement, Motherboard: 步骤 1 中的图像 1,3 Petcube Play 2 Speaker Replacement, Motherboard: 步骤 1 中的图像 2,3 Petcube Play 2 Speaker Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Flip over the Petcube so the rubber bottom faces you.
    • Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
  2. Petcube Play 2 Speaker Replacement: 步骤 2 中的图像 1,2 Petcube Play 2 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Speaker Replacement: 步骤 3 中的图像 1,2 Petcube Play 2 Speaker Replacement: 步骤 3 中的图像 2,2
    • Use an opening pick or spudger to pry off the glass front panel.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Speaker Replacement: 步骤 4 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 4 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 4 中的图像 3,3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Speaker Replacement: 步骤 5 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 5 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 5 中的图像 3,3
    • Once the internal assembly is removed, you should see a brass cylinder in the top left of the front face of the cube. At the top of that cylinder is a hole that leads down to a screw.
    • Remove it using a Phillips head size #1 screwdriver.
  6. Petcube Play 2 Speaker Replacement: 步骤 6 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 6 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 6 中的图像 3,3
    • Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
    • Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Speaker Replacement: 步骤 7 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 7 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 7 中的图像 3,3
    • Disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Speaker Replacement: 步骤 8 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 8 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 8 中的图像 3,3
    • Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
    • Carefully release the three tabs and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 Speaker Replacement, Speaker: 步骤 9 中的图像 1,3 Petcube Play 2 Speaker Replacement, Speaker: 步骤 9 中的图像 2,3 Petcube Play 2 Speaker Replacement, Speaker: 步骤 9 中的图像 3,3
    • Take the half of the device that doesn't contain the motherboard and place it down so that the top screws are visible.
    • Use a Phillips #1 screwdriver to remove the seven screws.
  10. Petcube Play 2 Speaker Replacement: 步骤 10 中的图像 1,1
    • Use tweezers to remove the wire connector attaching the two halves together.
    • Separate the two halves and isolate the one containing the speaker.
  11. Petcube Play 2 Speaker Replacement: 步骤 11 中的图像 1,2 Petcube Play 2 Speaker Replacement: 步骤 11 中的图像 2,2
    • On the other half of the cube, remove the four screws using a Phillips #1 screwdriver.
  12. Petcube Play 2 Speaker Replacement: 步骤 12 中的图像 1,2 Petcube Play 2 Speaker Replacement: 步骤 12 中的图像 2,2
    • Grip the flat bottom and the cover of the speaker and gently pull them apart to separate to expose the speaker.
    • Be careful when pulling the two apart to avoid damaging the other internal parts as they are connected by the speaker cable.
  13. Petcube Play 2 Speaker Replacement: 步骤 13 中的图像 1,3 Petcube Play 2 Speaker Replacement: 步骤 13 中的图像 2,3 Petcube Play 2 Speaker Replacement: 步骤 13 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two screws securing the speaker.
    • Use a soldering iron to desolder the wires connecting the speaker to the device.
    • Make sure to follow safety protocols with soldering and take your time as to prevent injury.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jim Clifton
于03/18/24注册
121 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 的会员
UMASSD-KONN-S24S1G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 8
总计 61
