跳转到主内容
Patching a Bicycle Tire Inner Tube
Travis Tonder
Travis Tonder8 其他贡献者
最后更新于 February 19, 2016
10 - 20 分钟
简单
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
你所需要的
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: 步骤 1 中的图像 1,2 Patching a Bicycle Tire Inner Tube, Rear Wheel: 步骤 1 中的图像 2,2
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: 步骤 2 中的图像 1,1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: 步骤 3 中的图像 1,1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: 步骤 4 中的图像 1,1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: 步骤 5 中的图像 1,2 Patching a Bicycle Tire Inner Tube: 步骤 5 中的图像 2,2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: 步骤 6 中的图像 1,1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 步骤 7 中的图像 1,1
  8. Patching a Bicycle Tire Inner Tube: 步骤 8 中的图像 1,2 Patching a Bicycle Tire Inner Tube: 步骤 8 中的图像 2,2
  9. Patching a Bicycle Tire Inner Tube: 步骤 9 中的图像 1,1
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: 步骤 10 中的图像 1,2 Patching a Bicycle Tire Inner Tube: 步骤 10 中的图像 2,2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: 步骤 11 中的图像 1,1
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: 步骤 12 中的图像 1,1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: 步骤 13 中的图像 1,1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: 步骤 14 中的图像 1,1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: 步骤 15 中的图像 1,1
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: 步骤 16 中的图像 1,1
    • Apply pressure to the patch until the rubber cement is dry.
结论
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6等其他人完成本指南。
Travis Tonder
于10/05/10注册
3,210 声望
创作了4篇指南
团队
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G13
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 28
总计 4,187
