跳转到主内容
加入维修社区 - 创建账户
Parrot Skycontroller 2 Power Port Replacement
你所需要的
    1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 3,3
      • Flip the controller upside down.
      添加评论
    2. Parrot Skycontroller 2 Power Port  Replacement: 步骤 2 中的图像 1,1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      询问修复机器人
      添加评论
    3. Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 3,3
      • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
      • Remove the cover by pulling up and out.
      添加评论
    4. Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 3,3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling apart.
      添加评论
    5. Parrot Skycontroller 2 Power Port  Replacement: 步骤 5 中的图像 1,2 Parrot Skycontroller 2 Power Port  Replacement: 步骤 5 中的图像 2,2
      • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
      • Some force may be required to separate the battery from it's brackets.
      添加评论
    6. Parrot Skycontroller 2 Power Port  Replacement: 步骤 6 中的图像 1,1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      添加评论
    7. Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 3,3
      • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      询问修复机器人
      添加评论
    8. Parrot Skycontroller 2 Power Port  Replacement: 步骤 8 中的图像 1,1
      • Remove the battery compartment plate by pulling up and out.
      添加评论
    9. Parrot Skycontroller 2 Power Port  Replacement: 步骤 9 中的图像 1,1
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      询问修复机器人
      添加评论
    10. Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 3,3
      • Remove the face plate by pulling up and out.
      添加评论
    11. Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 3,3
      • Make sure the controller is flat, then proceed to desolder the power port.
      • Desolder the four connection points surrounding the charging port.
      • Remove the power port from the controller.
      • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
      • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 869
