There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
Do not yank off the back plate. If you do, you will tear the electronic ribbons attached to the inside of the camera and the back plate.
Gently lift up the back plate, being careful not to damage any ribbons.
Do not yank out the electronic ribbons attached to the motherboard and the back plate, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
Do not yank out the electronic ribbons attached to the motherboard, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
Pull to disconnect from the motherboard the seven ZIF connector ribbons.
