跳转到主内容
Panasonic ER-GN30-K Motor Replacement
Corey Tappan
Corey Tappan4 其他贡献者
最后更新于 July 13, 2024
15分钟
中等
You have tried everything to attempt to make your device work again, if nothing has succeeded the motor may need to be replaced. Follow this guide on how to remove the motor.
你所需要的
工具
查看更多...
  1. Panasonic ER-GN30-K Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: 步骤 4 中的图像 1,1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: 步骤 5 中的图像 1,1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: 步骤 7 中的图像 1,2 Panasonic ER-GN30-K Motor Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the motor from the case by sliding the cover off of it.
    you are really awesome . How can I make it run on electricity
    Medo Medo - 回复
结论
6等其他人完成本指南。
Corey Tappan
于08/27/15注册
209 声望
撰写一个指南
团队
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G3
4 名成员
创作了10篇指南
2指南评论
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - 回复
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 65
总计 3,957
