跳转到主内容
Panasonic ER-GN30-K Blade Replacement
Jacob Hoofman
Jacob Hoofman2 其他贡献者
最后更新于 July 13, 2024
1分钟
非常容易
Is your blade not trimming like it used to? Check out this quick guide to replace it.
Note: The blade is sharp so be careful to not cut yourself.
  1. Panasonic ER-GN30-K Blade Replacement, Blade: 步骤 1 中的图像 1,1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Blade Replacement: 步骤 2 中的图像 1,1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  3. Panasonic ER-GN30-K Blade Replacement: 步骤 3 中的图像 1,1
    • Remove the blade from the cap by gently pulling it from the cap.
    • Even if the blade is dull or broken, it will still be sharp enough to cut skin, so be careful while you remove it.
结论
5等其他人完成本指南。
Jacob Hoofman
于09/03/15注册
413 声望
撰写一个指南
团队
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G3
4 名成员
创作了10篇指南
6条评论
Looked everywhere...anybody know where to get replacement blades for the Panasonic ER-GN30 nose & ear trimmer?
R Holmes - 回复
Did you ever find a replacement blade?
PCARRINGTON - 回复
I called Panasonic's support number, and supposedly the inner blade at least, is priced from around $14 to $20, from various places. Considering major resellers have the whole trimmer for around $12, it would not make sense to get just a blade. Amazon has open-box wearhouse deals now, where the trimmers can be had for under $5.00. I may get one of these myself :)
Jim Locke - 回复
Hola yo acabo de comprar las cuchillas a 7€ , les dejo el enlace https://juanluismartel.com ademas me repararon una camara Panasonic Lumix, Gracias.
usblsb - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 71
总计 13,558
