跳转到主内容
加入维修社区 - 创建账户
Palm TX Buttons and Connector Assembly Replacement
你所需要的
    1. Palm TX Buttons and Connector Assembly Replacement, Back Panel: 步骤 1 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement, Back Panel: 步骤 1 中的图像 2,2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      询问修复机器人
      添加评论
    2. Palm TX Buttons and Connector Assembly Replacement: 步骤 2 中的图像 1,1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      询问修复机器人
      添加评论
    3. Palm TX Buttons and Connector Assembly Replacement: 步骤 3 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement: 步骤 3 中的图像 2,2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      询问修复机器人
      添加评论
    4. Palm TX Buttons and Connector Assembly Replacement: 步骤 4 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement: 步骤 4 中的图像 2,2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      询问修复机器人
      添加评论
    5. Palm TX Buttons and Connector Assembly Replacement: 步骤 5 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement: 步骤 5 中的图像 2,2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      询问修复机器人
      添加评论
    1. Palm TX Buttons and Connector Assembly Replacement, Battery Pack: 步骤 6 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement, Battery Pack: 步骤 6 中的图像 2,2
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      询问修复机器人
      添加评论
    1. Palm TX Buttons and Connector Assembly Replacement, Motherboard: 步骤 7 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement, Motherboard: 步骤 7 中的图像 2,2
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      询问修复机器人
      添加评论
    2. Palm TX Buttons and Connector Assembly Replacement: 步骤 8 中的图像 1,2 Palm TX Buttons and Connector Assembly Replacement: 步骤 8 中的图像 2,2
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      询问修复机器人
      添加评论
    1. Palm TX Buttons and Connector Assembly Replacement, Display: 步骤 9 中的图像 1,1
      • Orient the device sideways, as shown in the picture.
      • Lightly push the front of the display to separate it from the front panel.
      • The battery in the picture will not be attached to the device at this point.
      添加评论
    1. Palm TX Buttons and Connector Assembly Replacement, Buttons and Connector Assembly: 步骤 10 中的图像 1,1
      • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
      • It may take some manipulation to remove the screws.
      询问修复机器人
      添加评论
    2. Palm TX Buttons and Connector Assembly Replacement: 步骤 11 中的图像 1,1
      • Lift the button and connector assembly from the front panel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G15
4 名成员
创作了23篇指南
1指南评论
Where can you buy one of these?
Sean Madawala - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 45
总计 2,111
