跳转到主内容
PSP Go Battery Replacement
Miroslav Djuric
Miroslav Djuric6 其他贡献者
最后更新于 September 20, 2023
15分钟
中等
特色指南
This guide shows how to remove the PSP Go's battery.
你所需要的
配件
工具
查看更多...
  1. PSP Go Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 PSP Go Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Battery Replacement: 步骤 2 中的图像 1,2 PSP Go Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Battery Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Battery Replacement, Left Trigger: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to gently flip up the left trigger connector.
  5. PSP Go Battery Replacement: 步骤 5 中的图像 1,2 PSP Go Battery Replacement: 步骤 5 中的图像 2,2
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
  6. PSP Go Battery Replacement, Battery: 步骤 6 中的图像 1,3 PSP Go Battery Replacement, Battery: 步骤 6 中的图像 2,3 PSP Go Battery Replacement, Battery: 步骤 6 中的图像 3,3
    • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
    • Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
  7. PSP Go Battery Replacement: 步骤 7 中的图像 1,1
    • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
    • Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
    • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
    If you are having trouble charging up your system. Try reseating the battery connector of this step before purchasing a new battery. This is a common problem with PSP go systems that haven't been used for a while. If the battery still doesn't charge after reseating the connector, you might need a new battery.
    FinWZ - 回复
  8. PSP Go Battery Replacement: 步骤 8 中的图像 1,2 PSP Go Battery Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
    • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
结论
20等其他人完成本指南。
12指南评论
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
mainemade4u - 回复
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
mainemade4u - 回复
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Mus Mohamed - 回复
Cfw 6.61 pro update. Helppp
Mus Mohamed - 回复
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Marvin Arand - 回复
Excellent guide, PSP go works like new!
Ryan Solusod - 回复
I bought a replacement battery online for my PSP Go, but it came without the white connector. Have you an idea how to fix it?
anibaal.d.jiraiya - 回复
My psp go is not charging but when I connect it my laptop is get connected any idea what is going on
dawooddjmax - 回复
I knew how to do it but I love this site and it does help
KingHeadass - 回复
Amazing guide that makes the process simple! As a heads up for future users of the guide: If you are having trouble charging the battery of your PSP go, try reseating the battery connector. and check if the device starts charging. This is a common problem with PSP go's that have sat dormant for a while. You might not need a new battery and just need to reseat the old ones connector. I hope this comment might save someone time and money! Cheers!
FinWZ - 回复
How can I reset the battery?
Mikazuki Yamamoto -
You will need to open up the consoles back cover and then carefully unplug thr battery connector and then plug it back in.
FinWZ -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 134
过去 30 天: 503
总计 98,192
